77' 280z T5
Old May 29, 2002 | 09:23 PM
zguy36's Avatar
Dead
Re: 77' 280z T5
I had the same problem when I did the swap. Did you put in gear lube or ATF? A lot of the Borg Warner trannys use ATF instead of the normal gear lube. If you used gear lube, then that would account for the harder shift into first. I used ATF in mine, but still had the harder shift into first and reverse, but after a month or so of driving, it loosened up and is now working fine.
-jeremy-
