76 280Z Vacume question
Old Apr 17, 2013 | 05:30 AM
Vedivan's Avatar
I just got done going through the entire fuel system. Cleaned the tank, new fuel filter, added another fuel filter between tank and pump, replaced all injectors, and fuel pressure sending unit. Started it up, and runs ok. stutters when you rev it up. it's running way rich. I think it's a vacume advance issue. I followed the main vacume line coming off the intake to the canister thing located in the front right corner of the engine bay. This appears to be a vacume distribution device, right? When I remove the intake tube from the canister, the engine idles much higher. When I replace it, and remove any of the other vacume lines, there doesn't seem to be any vacume coming from the canister. It would seem to me the reason for the stuttering and running rich is that when I rev the motor, the timinmg may not be advancing and therefore not burning all the fuel being dumped into the cyl. What do you folks think? Sugestions?
Old Apr 22, 2013 | 09:08 PM
theramz's Avatar
I have a present for you...
Download the fsm and make sure your vacuum lines are hooked up correctly with no leaks.
XenonS30
JayArmor
Nov 27, 2009 11:45 PM
DominAzn
Jun 7, 2009 02:16 PM
rtmorgan
Oct 7, 2008 10:49 AM
snwbrderphat540
49
Jun 25, 2007 10:31 AM
