76 280Z Sputters when accelerating
Subscribe
May 16, 2013 | 07:35 PM
Here's the run down. I've removed the fuel tank and had it cleaned. I installed a fuel filter between the tank & fuel pump. I replaced;
  1. Fuel filter
  2. Fuel injectors
  3. Fuel Pressure Regulator
  4. Plugs
  5. Coolant Temperature Sensor
I drove the car for the first time since buying it. It drives fine when I'm just barely accelerating. But when I try to accelerate aggressively, it will sputter, to the point of dying if I don't lift my foot.
Any suggestions?
Thanks
Reply
May 16, 2013 | 08:29 PM
Check your Throttle switch, its the little black box on the side of the throttle body. It may be dirty or damaged. Or just simply needing adjustment.
If that doesn't help you may want to check your AFM
Reply
May 28, 2013 | 07:51 AM
I ordered the TPS. (start with the cheaper part) should be here Friday
Reply
May 30, 2013 | 10:19 PM
Sounds like the afm. If its a non-turbo there pretty cheap.
Reply
Jul 1, 2013 | 02:04 PM
check for a leak at boot between AFM and throttle thats assuming you have checked fuel pressure
Reply
Apr 25, 2014 | 08:52 AM
I second the notion of the AFM boot leak, also may want to check the EGR valve and EGR valve tube if it hasnt been replaced yet, some simple things cause a world of trouble.
How do the spark plugs look ? Does it have a cat converter ?
Reply
Subscribe
