73 240z, brakes and startup woes
brakes: screech loudly when i apply medium pressure.. light/hard pressure stops the brakes from making a noise. pads new within 10,000 miles.. i wouldnt need to replace that soon, right?
startup: takes 2-3 seconds for car to start after letting sit for a few hours... would suspect CSV but will do this even if its 100+ degrees outside. crane electronic ignition. any help would be greatly appreciated, thanks |
you could have put the safety clip on wrong on the brakes, and it'll screech if you did. I don't know why it'd take so long for the car to start, check your carburetors, maybe you're not getting enough gas.
