73 240 missing timing after replacing radiator
Old Jul 7, 2010 | 08:00 PM
BoKnows's Avatar
My '73 was running well until I replaced the radiator. It doesn't want to start (turns over). I changed the fuel filter thinking it might be fuel starved. After getting it started (stretching the starter motor to within an inch of it's life), it was only running on three cyl. Changed the plugs and added performance wires, bought a new cap and rotor. Started a little better but was still missing. The car quit running and wouldn't re-start until I took the air canister off, but still was missing.
Where do I go from here?
Old Jul 7, 2010 | 08:38 PM
skittle's Avatar
Taste My Rainbow
Check all Vacuum lines and make sure you have the timing set right
1,5,3,6,2,4 counterclockwise from the #1 posistion
Old Jul 8, 2010 | 12:47 AM
Old Jul 8, 2010 | 08:11 AM
BoKnows's Avatar
I did check the wires to the cap to ensure they're in the right position. Also, I pulled the #1 plug that was brand new and with just a few starts it was black with soot (not oil).
I will double check the vacuum lines, but I'm still confused because nothing else changed other than the radiator.
Old Jul 8, 2010 | 09:07 AM
BlueKitsune's Avatar
Intrawebz Wizard
Black with soot? its running extremely rich then. I'd check plugs 3 and 4 and compare them. maybe one of the 2 carbs needs adjusting.
Jason280ZX
Dec 31, 2013 04:11 PM
rteekel1
Mar 26, 2012 11:57 AM
garretthes
Dec 22, 2011 11:15 PM
Qic12c
Sep 20, 2010 06:54 PM
Dave Hamby
Sep 1, 2006 12:18 PM
