60mm throttlebody
Guest
Posts: n/a
Re: 60mm throttlebody
I've been wondering the samething. I bought a throttle body and have been wondering how to install it. As best I can tell a Spacer plate is required as well as a porting job. The throttle linkage can be swapped from the 280 onto the 240sx shaft. From what I can tell a lot of the 240sx had cruise control, which means you have to cut the shaft down. The throttle position sensor has the same plug in as the 280, but there are three extra wires. This is where I need help also, I'm not sure where the hoses on the 240sx throttle body hook up, there are a couple extra. Any more help would be appreciated.
mescalinedreamz
Aug 1, 2003 05:35 AM
