280Z Tachometer Repair
Old 08-26-2014, 02:57 PM
TedEZ's Avatar
I posted this from my phone the other day and deleted it somehow, so here it goes again.
Do to my lack of success searching for info on Tach repair I thought this may be of use to someone.
My tach needle was stuck at 1K with no response from any RPMs, four letter words or beating on the dash.
After you've removed the tach (sounds easy) from the dash start by pulling the black plastic shroud. Mark and pull the bulb mounts and signal wire. Disconnect and remove the wires and locknuts and plastic mount from the two wires with eyelets.
Next, remove the two little silver machine screws on the back (mind your tach needle on the other side).
At this point the dial and innards should be loose and may you may need to gently brake the old crusty cushion loose from the back by pressing on the brass screws from the backside.
The first problem is an old electrolytic capacitor, the one that looks like a little grey or black beer can. UPJ1H390MED Nichicon | Mouser
After about 25 years these usually dead or very near it.
A very simple 5 min. with a soldering iron and a $ .35 part fixed that.
Now to free up the needle I just gently put pressure on various parts of the tach dial while flipping the needle to find out what and where it was binding. It seems the brass supports under the dial face just needed a minor tweek. I just used a small screw driver and bent the braces very slightly and presto, a smooth needle. Be very careful not to bend the little coil springs inside.
Assemble and test tach an bulbs prior to shoving tach back into dash.
Happy revving.
Attached Thumbnails 280Z Tachometer Repair-dsc_0738-1.jpg   280Z Tachometer Repair-dsc_0739-1.jpg   280Z Tachometer Repair-dsc_0740-1.jpg   280Z Tachometer Repair-e-pj.jpg
Last edited by NismoPick; 08-27-2014 at 07:53 AM. Reason: Added picture of capacitor# UPJ1H390MED
TedEZ is offline
Old 08-27-2014, 07:51 AM
Wow! Nice first post!
This is very useful info as the S30 tach's are prone to this kind of death. I have made a copy of this thread in our Gen Tech area:
https://www.zdriver.com/forums/240z-...-repair-40153/
NismoPick is offline
Old 08-27-2014, 09:10 AM
beg3yrs's Avatar
Yes, thank you! Pretty sure this will be useful in the restoration of my 260Z.
beg3yrs is offline
Old 11-07-2018, 03:19 PM
Zebulan9's Avatar
78 Z tachometer wanted.
I have a tach removed a few days ago from a 78 z with 02367 miles on the car. It went over a 100k so the tach has 102, 367 miles. Asking $170 shipped.
Zebulan9 is offline
TedEZ
08-26-2014 02:57 PM
fast eddie
04-04-2005 07:49 PM
brentcline
02-04-2005 05:00 PM
serg92
11-25-2002 11:05 PM
wiebejosh
04-14-2001 06:10 AM
Quick Reply: 280Z Tachometer Repair
