1978 280z heat?
Old Nov 21, 2012 | 04:28 PM
wallace millner's Avatar
1978 280z heat?
hi i have a 78 280z,when i turn heat on it blows cold air.I can open the flap door behind blower motor(well on blower motor housing)and it turns hot.Could the heat control valve be stuck closed or bad.checked all vacuum hoses all connected.
Old Nov 22, 2012 | 07:01 AM
77280ZX's Avatar
I'm having this same issue. And I am stumped. I even replaced the heater control valve. When I accelerate all the air moves to the vents but won't blow hot air
Old Nov 22, 2012 | 08:39 AM
77280zx while car is running and heat is on go to passenger side reach behind heater blower and push flap door and see if it heats up.
Old Dec 1, 2012 | 07:19 PM
77280ZX's Avatar
It doesn't
Old Jan 12, 2013 | 03:01 PM
aaronis31337's Avatar
Check your heater vacuum hoses. They are on the right-hand side of the engine bay close to the cabin. You will see 1 hose coming from inside the firewall. Trace that hose to the cluster of hoses attached to the side of the engine bay. These hoses are prone to fail after a couple of years, so this is a common problem (mine are failed too). It's a easy fix, if you're careful. The failure will occure where the hoses end -- so look for a split in the hose near the end.
Let me know how it goes. Good luck.
klearkustoms
Jan 22, 2014 02:03 PM
wallace millner
Jul 18, 2012 05:39 AM
Texizgreat
Jan 2, 2008 06:41 AM
TheCobra
Feb 26, 2007 12:36 PM
Jammer
Aug 3, 2003 05:14 PM
