*SOS * No Compression!!!HELP!!
Old Oct 5, 2003 | 08:24 PM
theramz's Avatar
I have a present for you...
Take out all the plugs and one by one put your thumb over the hole while some one turns it over. You should get enough pressure to at least blow by your thumb. A compression gage works better. You could have "jumped time" if the chain seems loose. If this happens you will have some bent valves and no compression in those cyclinders. Say AHHHHHHH ****! Time to pull the head, pan and front cover not to mention all the other stuff in the way. let us all know how you make out. Good luck
Old Oct 9, 2003 | 01:42 PM
Speed's Avatar
? Have you got Juice?
If it won't turn over, is your battery low or down? You car has an alternator, so it won't bump start like an old VW with a generator!
Check and see if you have good spark, for the starter, coil, sparkplugs, etc.
If you have juice, and the motor turns over, check the spark at the spark plugs, you may still have weak spark. Some of the newer cars need at least 11.9 volts to operate all of their electrical components to make the motor run.
If you have juice, spark, and the motor turns over, but you still lack compression, it may be a head gasket, or valve. You would almost need low oil pressure to allow the chain to jump timing on the cam or crank.
Hope this gives you some ideas. Check out your electrical first, before tearing the head off!
Speed
boggiewan
Feb 11, 2013 04:19 PM
90NA300ZX
12
Nov 16, 2005 07:52 PM
kolts
Oct 26, 2002 06:36 PM
stormy
Apr 2, 2002 09:13 PM
Zpeed
May 17, 2001 03:16 AM
