Z32 carrier bolts for R200 ring gear
I am tring to use a Z32 carrier and a R 200 ring gear 10 MM bolts in ring gear and 12 MM holes in carrier. any one know where to buy bolts for this setup.
No such bolt but you could have bushings made to press into the carrier. A close fit is necessary to keep the 10 mm bolts from loosening.
