whats that sensor
Old May 6, 2012 | 11:40 PM
Dat Z Sun's Avatar
whats that sensor
hey guys, i just bought a 75z, it runs but like ****, thats not why im posting this, id like to kno whats the sensor on the top of the intake manifold right after the throttle body, mines corroded to ****, thanks
Old May 7, 2012 | 02:55 AM
It's a sensor that measures a certain set of values. Could you be a little less specific?
Old May 7, 2012 | 10:03 AM
There's no "sensor" on top of the manifold right behind the throttle body.
There is a cold start valve though...
Might want to buy a Haynes manual or download the FSM for free from XenonS30
Old May 7, 2012 | 08:47 PM
Dat Z Sun's Avatar
does the cold start valve have a pigtail that looks like an injector pigtail that has 4 wires going into it, 2 on each side?
Old May 7, 2012 | 08:49 PM
It's an injector style connector, but only has 2 wires... I don't think there are any sensors that have 4 wires except the AFM ...
Old May 8, 2012 | 07:10 PM
Dat Z Sun's Avatar
heres the pics, you're right about the valve but it has 4 wires to it
is there any way to test it before i go and spend 60 bucks on a motor that ima swap out here in a while?
Old May 8, 2012 | 08:25 PM
Notice there are only two prongs... so there should only be two wires. I imagine the two each side are connected as one. Been about 10 years since I've looked at n/a wiring in detail.
Anyway... why not clean it up instead of buying a new one? Dip the tip that goes inside the intake in brake cleaner or lacquer thinner, dip the top connector prongs in LimeAway or CLR. Done.
Old May 8, 2012 | 09:05 PM
Dat Z Sun's Avatar
nice tip, my fuel injector pigtail were corroded as well, but i just snatched some good ones from the junk yard, gotta order a fuel pump and pray soldering new injector pigtails and cleaning the cold start valve do the trick
nick731
May 8, 2012 07:38 AM
rgus30
Dec 18, 2006 06:36 PM
grey_turboae86
Aug 16, 2006 07:47 PM
njordal02
Dec 17, 2003 02:59 PM
CrAzY_84na
Sep 23, 2003 07:00 PM
