ZDriver.com
-   240Z, 260Z, 280Z Performance / Technical (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/)
-   -   What EGR plug do I need for 1978 280Z? (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/what-egr-plug-do-i-need-1978-280z-32275/)
dankfrye@charte Mar 24, 2011 04:28 PM
My EGR tube on my 1978 280Z has a bad exhaust leak where it comes out of the manifold. The past owner tried to repair it with metal tap but that obviously didn't work too good. I want to take it out and plug the hole in the manifold. I've done a lot of research on the correct plug size but can't seem to get a common
answer. I've heard 22mm, 3/4 NPT Brass and several others. Does anyone know the correct plug that I need?
Thanks'
Dan
evandubya Mar 24, 2011 06:08 PM
I don't know if you have a welder, but I just welded the hole up in the fitting thats in the manifold. It can still come out I just turned it in to a plug.
dankfrye@charte Mar 24, 2011 07:22 PM
Thanks for the suggestion! My body man has a welder and we might do that.
NismoPick Mar 24, 2011 08:53 PM
Welding is an option... you could also just take off the pipe and take it to your local parts store / hardware store and find a match.
dankfrye@charte Mar 25, 2011 12:31 PM
Will do! Thanks!
