Tuning Triple Weber DCOE's
Anyone have a good link, or something with a picture or two?
I think that my throttle plates are misaligned, and causing a lean issue above idle through around 3,000rpm. I understand that there is a way to position these correctly while the carbs are still on the engine. Can anyone tell me where to look to get them lined up correctly? |
the haynes weber manual was always my best recource. i always looked to the emulsion tubes for a problem in the mid RPM's. but then again i only had one instead of 3.
this might help. http://www.redlineweber.com/html/Tec...f_contents.htm
Awesome, I think that link will be the best help I have found.
