Throwout bearing
Old Oct 19, 2009 | 11:20 PM
domsgarage's Avatar
Tough Guy
Throwout bearing
Ok, heres the issue.
Got a l28et engine clutch pp but s130 n/a 5 speed.
What throw out bearing and collar do I need to use?
I already have an n/a bearing and collar, fork and an adjustable sleeve, but is this a solid set up or will I run into issues?
Do the collar and bearing have to match the trans?
Any help is greatly appreciated.
Old Oct 19, 2009 | 11:22 PM
BlueKitsune's Avatar
Intrawebz Wizard
the Turbo one of course. You use the T/O bearing that matches the clutch pressure plate.
Coupe Clutch use a Coupe T/O
Turbo/2+2 Clutch use a Turbo/2+2 T/O
Old Oct 19, 2009 | 11:27 PM
domsgarage's Avatar
Tough Guy
you know the size comparison?
Old Oct 19, 2009 | 11:34 PM
Intrawebz Wizard
Of the clutch, yes. Of the T/O, no. Sorry. But anyways thats what I was told and it seems right to me seeing as the turbo/2+2 clutch is bigger in size.
Old Oct 19, 2009 | 11:38 PM
domsgarage's Avatar
Tough Guy
alright cool, thanks, im asking for a friend of mind so ill let him know what you said.
Old Oct 19, 2009 | 11:45 PM
Intrawebz Wizard
Alright. doesnt help to double check the info! Also doesnt help Im half asleep lol
Old Oct 20, 2009 | 08:10 AM
^^^ lulz.
Old Oct 20, 2009 | 02:19 PM
theramz's Avatar
I have a present for you...
Forks are the same for 73-83 na. 82-83 Turbo cars have different forks and yokes because of the T5 trans. Actual bearing is the same from 70-89. And yes the clutch and disc are bigger with a heavier flywheel on the turbo and 2+2. Larger flywheel, damper and clutch are for the much heavier cars. You will net more HP with the lighter parts and buy a good clutch.
Old Oct 20, 2009 | 02:28 PM
Intrawebz Wizard
The flywheels weigh the same. its the surface area thats diffrent
Old Oct 20, 2009 | 10:16 PM
domsgarage's Avatar
Tough Guy
then the n/a sleeve with the bearing on it should work for the turbo/2+2 clutch flywheel and n/a tranny?
Old Oct 20, 2009 | 11:27 PM
Intrawebz Wizard
I got bored and looks this up. The bearing itself. all have the same part number from 70 all the way to 89. Seems to be the same for the collar. So It will work for w/e you want to use apparently...
Note to self: Always double check what you read by first confirming its true if possible.
Old Oct 21, 2009 | 10:19 AM
domsgarage's Avatar
Tough Guy
Cool thanks.
Hes gonna use the NA one.
Ill let you know if something snaps or blows up.
Old Oct 21, 2009 | 11:30 AM
TrumpetRhapsody's Avatar
I doubt anything would snap or blow up... more likely is the simple inability to disengage the clutch from the flywheel.
Old Oct 21, 2009 | 11:35 AM
domsgarage's Avatar
Tough Guy
well... id like to see something explode.
Old Oct 22, 2009 | 02:00 PM
theramz's Avatar
I should have been more specific. The 280 flywheel weighs 10.5kg and the 240 weighs 9.5kg. (2.4 lbs plus the bigger clutch.)
WanganDevilZ
Aug 27, 2012 06:44 PM
Fast240Z
Oct 19, 2007 08:58 PM
duowing
Mar 12, 2006 08:08 PM
G00DHUM0R
Dec 9, 2002 04:40 AM
zxracer90
Apr 26, 2001 08:19 PM
