Strange miss.....
Trying to work the bugs out of my recently aquired 78 280Z, and for the most part have it running great. The problem I am experiencing is an inconsistent, stubborn miss while driving the car, and occasionally when idling the car.
The car will run great (driving the car) when suddenly it will start to miss. Any attempt at hitting the throttle while this is happening results in a miss, and in any gear (5 speed) the miss is the same and will not allow the car to accelerate. Stopping the car, the car will continue to run roughly at approximately 500 rpm- giving any throttle and the car will still miss in neutral. Putting the pedal to the floor, the car will stumble and die. Sometimes it will clear up and the car will run normally again....Now here is the strange thing- I have discovered that when this happens, turning the key off and then back on (whether in neutral and restarting or while still in gear and just turning the key back on) fixes the problem immediately, until it happens again, usually within 3-5 miles..Other than this, the car runs great. Regardless of whether I'm driving or idling in neutral, the key off and back on approach fixes the problem temporarily. Any suggestions? My suspect areas are mass air meter, coil, air temp sensor or possibly ECM...? I'm new to these cars but am learning. Any suggestions would be appreciated. Thanks!! |
My guess, and I'm not as good as lot of the other guys around here, are going to be your air flow meter or your distributer. Check out some of my posts describing some of the problems I've been having and see if any of it sounds familiar and then.
Yeah, I think the prime suspect would be the meter as well. I'll check out some other posts, thanks for the input! |
Grrrrrr
Checked the AFM, potentiometer is good and all of the contacts are within factory spec's. Air temp sensor is working as well within spec's.....time to go to the ignition I guess... :(
Throttle position switch contacts (on the the throttle body) are a possibility, and perhaps the water temp sensor (also check that your coolant is topped up enough, too, or the sensor won't be immersed). Also possibly your alternator (there are some other posts on the details of the alternator/fuel pump link, somewhere around here)
good luck, Dave |
good luck, Dave Actually, I believe the mass air meter is the culprit. I checked this again and discovered there is a problem with the potentiometer in the MAF sensor. Operating the flap, the reading is 6V @ start. Moving the flap immediately takes the voltage to around 2V, then the voltage drop is gradual. The jump from 6V to 2 volts is definitely a problem. I don't know what the voltage should be with the flap closed, but the voltage drop should be gradual, with no sudden voltage drops. If this doesn't fix the problem I'm going to try the throttle switch. Water temp sensor is new and functioning correctly, as is cold start valve...Thanks for the input! |
Glad it sounds like you've got it isolated. Sorry it turned out to be the really expensive part. :(
Dave |
Dave |
I've not seen one personally, but hopefully someone here has. I vaguely remember somebody kind of building their own a year or two ago, using pieces off of other cars (240SX or Maxima, maybe?). All you really need to do is replicate that voltage curve from the potentiometer. It'd be some tinkering but probably quite do-able. Sorry I can't remember where I saw that info/article... maybe someone else here does?
Dave |
I seem to be having a similar problem with my g/f car....she has a 76 280z. we recently replaced the afm with a remanufactured one...nothing seemed to be a problem with it....but we put it in and went for a test drive and we shift into 2nd gear and get the pedal about half way to the floor and it feels like no fuel is getting to the engine for combustion! could anyone help me out with this? would a fuel pump be the problem? or new air filter or ?? not to familiar with this area of the car....any help would be greatly appreciated!
Dave I thought of this too, but the problem I see with this is compatibility between plugs from the harness. I have looked at several meters, most have 3-5 contacts, I believe the 78 is around 10 contacts. I guess if you know what each contact is for you could do this, but would it be more trouble than it is worth? The replacement meters aren't cheap though. The cheapest I could get one was $161 (with core). |
Hmmm
