ZDriver.com
-   240Z, 260Z, 280Z Performance / Technical (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/)
-   -   Putting it back together slowly... (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/putting-back-together-slowly-40373/)
Pez Nov 7, 2014 04:04 AM
Feels remarkable to actually be putting things back on the car...
This is after the EGR and cold start gear deletes. I had the intake itself media blasted.
Still need to sort out the fuel line routing and the regulator, but am on the path for that. Will likely do a few bonus projects along the way, like cleaning up the thermostat housing / gasket. Also need to address the lower fitting for the AAR coolant line. hoping to find a place locally that has a fitting without the 'T'.
Obviously the wiring harness is not present, hopefully will get some time to geek out on that and make it really tidy.
http://scontent-a-ord.cdninstagram.c...46159053_n.jpg
