Pump Relay
Old Jun 3, 2006 | 01:38 PM
FubarI33t's Avatar
Pump Relay
Alright guy's. 76 280Z. Where the heck is the fuel pump relay located at?
Old Jun 5, 2006 | 10:31 AM
naviathan's Avatar
Under the hood, in a black box on the passengers side. Can't remember which one exactly though. What's the issue at hand? The relays don't really go bad much.
Old Jun 5, 2006 | 12:12 PM
FubarI33t's Avatar
The pump won't turn on with iggnition. It will if we hot wire it with a toggle switch.
http://i48.photobucket.com/albums/f2...060506_002.jpg
http://i48.photobucket.com/albums/f2...060506_001.jpg
Old Jun 6, 2006 | 07:34 AM
naviathan's Avatar
The fuel pump switch is in the AFM. It doesn't turn on until the engine is turned over and the sucktion pulls the AFM flap open.
Old Jun 6, 2006 | 08:11 AM
Z350BOY's Avatar
Are you sure??? Every time I start the car I hear the pump activate as soon as I start to turn the key. The sound comes from the rear of the car.
Old Jun 6, 2006 | 10:25 AM
BoulderZ's Avatar
When you crank the car to start an EFI S30, the relays and logic that normally control sending power to the pump are bypassed. When you let off the key from "Start" to just plain old "On", the logic comes back into play. The fuel pump relay is in that box naviathan mentioned. It doesn't close unless your alternator is actually producing a charge. I found this out the hard way once testing the pump first, then the relay, and then the next piece upstream in the schematic was the alternator. Mine was dead.
Though I haven't looked at the schematic in awhile, I do remember there were more pieces to the overall logic circuit powering the fuel pump, and I wouldn't be surprised if naviathan's right about the AFM being one piece of the puzzle. If you don't already have a schematic for the car, you'll definitely want to get one. It's pretty easy to work on with that diagram, and just about impossible without it.
good luck,
Dave
Old Jun 6, 2006 | 10:41 AM
FubarI33t's Avatar
would be nice to have that black box under the hood like my s130. but it's just not there.
Old Jun 6, 2006 | 10:50 AM
BoulderZ's Avatar
I wonder where it is on the '76s? On my 78's it's always been on the passenger side (all lefthand drive cars), mounted on the fender well, just behind the wheel, just in front of the battery and just in front of the inspection lid for the battery. The fusible links are mounted to the box, too, and two major wire harness plugs are clipped to it.
Really weird for them to have moved it, but there must have been some reason...
Dave
Old Jun 6, 2006 | 11:03 AM
jfairladyz's Avatar
Fubar, has the car ever run since this person had it??? Maybe the relays have been removed.
Old Jun 6, 2006 | 11:29 AM
FubarI33t's Avatar
yeh. we start it up once a week to keep motor fresh, just runs rich since the regulator is Fubar and the fuel pump in on a toggle switch
Old Jun 6, 2006 | 11:58 AM
jfairladyz's Avatar
But has the car started on its own without the toggle switch??? Was this car picked up from a junkyard? If so then there's a good chance that the relay was picked out of it which would explain why you can't find it
Old Jun 6, 2006 | 03:44 PM
FubarI33t's Avatar
no, it can start on it's own, till the gas in the lines runs out. And no it was not from a junk yard. just a bad relay or wire i have to track down.
Old Jun 26, 2006 | 09:12 AM
PooFlinginMonke's Avatar
I normally use a razor knife to cut the silicone on the air flow meter cover and check usually find the switch contacts to either be dirty or the springiness has weakened over time. Usually just takes a slight tweak with some needle nose pliers to get it proper.
wrenchwench
Apr 6, 2015 03:27 PM
Silv3rstar
Feb 26, 2013 08:46 PM
kbowden
Jul 14, 2012 08:15 PM
LVZ280
Aug 8, 2011 06:48 AM
Loggerboy666
Oct 7, 2003 12:43 AM
