problems loosing cillendars
Hi,
I'm having problems with my z. It seems that once I've warmed the car up like on the freeway, and stop for about 10 minutes and start her back up, I loose about 3 cillenders. Then I get frustrated and punch the gas pedal a few times and she sounds like she's coughing up a fur ball and finally it kicks in. It seems like it might be engine electrical, although I'm not sure. My mechanic doesn't seem to have any idea at this point. He put new plugs, coil, he checked my injectors, my plug wires seem to be good. I can't stand it much longer! any ideas I'd love to hear them.:confused: |
Post your problem here:
http://www.zcar.com/forums/list.php?f=1 Those guys seem to know alot, but try spelling it "cylinder" so they don't jump you on that instead... |
thanks
my friend had a similar problem in his Thunderbird and there ended up to be water under the distributor cap. Check just for the heck of it.
the problem
check your afm that might be the problem because that is what is wrong with mine also
