Performance Parts
Where is the best place to find a variety of upgrades for the L26 motor and drivetrain? I'm looking for everything from alternators to camshafts to bearing caps (and everything inbetween) for the motor, and other drivetrain parts. I would like to make 300-450HP just on the motor. No nitrous, no turbos. The only possibility would be a supercharger, but I want the engine bay to stay somewhat clean and assessable.
Also, what is the weakest point in the car? My junk-body 260Z is going to become a drag style car, but it has to be streetable power. |
for shame! search function, number one rule of forums.... coulda answered most of your questions or at least helped you ask LESS vague questions. so ill answer the ones i dont think you can find super quickly. 300-450 on an ALL motor L6 is dreaming your ass off. you can pray for 300 on a stroker high compression motor with triple webers or ITB's. its a fawkin build and a half. and if its a drag car with streetable power, dude, go turbo. its the only way.
as for weakest point, no real such thing, but if you want big power a little frame strengthaning, just a little, and cage would be good, and the trannies and rear diffs in these car wont take much more over 200hp. |
Well, I appreciate your response even if it was mostly in a negative tone. I had already searched, and that got me to zdriver.com from google and yahoo. Since their searches didn't come up with much, and my quick viewing of threads around, I thought it would be best to become a member and ask.
I figured that it wouldn't be possible to do without a major power-adder. Although turbos are the most efficient power adder available, this is a build I am doing in my garage, and a supercharger will be less scraped knuckles and curses than a turbo system. As to the rearend and transmission, what are available for options? I would like a 5-speed or better manual that can handle some horsepower. And yes, I will search the threads next. |
options are unlimited if you can fabricate. most popular though for high HP power applications are a Z32 transmission and a early 90's Q45 rear end since they sell most of teh parts to complete those swaps on sights like arizonazcar.com
and that wasnt negative, not from me you dont have to worry about that. thats actually how i found this sight as well. but search on here we have a search function at the top of the page. and you can find mod options and such. and if you pick up maximum boost by corky bell this wonderful book explaining turbo systems, you wouldnt think they were so spooky after all. they are very very simple systems and with the 81-83 280ZX's using the same drivline but offering a turbo option you have that swap right there, and can achieve that 450hp level much easier-ly. |
go over hybridz.org and do alot of reading. you have to be ready to pay a good penny on all motor for those numbers. rebello can build you a motor to that specs but it wont be cheap. yes nissan does have 5 speeds that can handle more hp then that.(ex.sx tranny=300 hp or the 87-89 turbo tranny has the same guts as a z32 tranny which they both can handle more then ever wont on a z)
well, the Z32 manual tranny has handled jsut about anything tossed at it so far. lol. its a very resilient transmission. and if you ever want to ditch your SX tranny setup sporker..... gimme a holla!!!!!
is the z32 tranny your talkin about the one they used in the very last run of the z31?
are the bell housings the same? |
well i was looking for the same thing you were, about 300 hp pn the stock motor. i did some research and worked with a guy who builds rebuilt engins and we built an engine with about 300 hp. we used ...
big bore kit p90 heads 3 angle valve job stage 3 performance cam set f54 l28 block 89mm flat top pistons 240z rods ld28 maxima crank comprtition head gasket new bearings new gasket set new oil pump new water pump new timing chin set coated 3-2-1 header new injectors performance flywheel inlarged throttle body and a cold air intake and performance exhaust most of these products can either be found on http://www.thezstore.com/store/merchant.mvc? or http://arizonazcar.com/ some of the parts he had to search for because there hard to find |
thats close to a 6+k motor. so easy just to turbo and turn the boost up till things break i guess. guess if u want a n/a motor what he has is great. with that amount of money a 383 or even a 350 could easily do what your looking for.
alot of that are definitly yard parts though
p90 head Diesel maxima cam 240 rods f54 block and the cold air could be obtained for fairly cheap in decent condition needing some or no work. it all depends on how you wanna do it though is the maxima cam that much longer lift/duration? |
p90 head Diesel maxima cam 240 rods f54 block and the cold air could be obtained for fairly cheap in decent condition needing some or no work. it all depends on how you wanna do it though is the maxima cam that much longer lift/duration? and they are very hard to find or if you buy one its very expensive. |
oh i thought he said cam, crank still....unless i am sitting on cache of diesel maximas here which i doubt, they arent hard to find HOW EVER in california they have stupid laws so they may be hard to find there since they were all yarded or shipped off some place else like here which isnt to far away
i would still think the cam and the head would be different being diesel and all |
fine, if you find a maxima diesel crank, grab one for me please.
ok dokie
how much, since you say theyre rare and all |
lol, hell no buddy. i will compensate your for gas a 8 bucks an hour you work on getting it out. your the one that says you can find them so easily.
alright i'll rember that
"with that amount of money a 383 or even a 350 could easily do what your looking for."
A 383 fits in that bay? I have a good running 383's lying around here, making 273 HP, 285 ft/lbs if I remember correctly... (was built for a dirt-tracker) What would I need to get it to fit? I'm assuming I have to modify to get a dodge tranny in there, along with the rest of the drivetrain... Well, before I jump overboard, how difficult is it to fit the 383 to fit AND run? |
thats what i was thinking ^^^^
and then asked myself, its only making WHAT for HP and tq ???? boooooo.... lol there are plenty of chevy conversions out there. search google and you'll come up with on site dedicated to them and teh products to finish the swap. you can also try thezstore.com |
hahaha yea sorry a stroker i had to scratch my head for a second when u said 273 HP, 285 ft/lbs....but dude anything will fit if you got the time and money. a guy in our club has a 440. alot of cutting and alot of busting knuckles.
