Ignition Guru's
Ignition Guru's
guys looking a a 78 for this girl, unknownn how long since it has run, said it started with fuel leaks and just let it sit for a long time.
Anyway this has got me a bit puzzled, when you turn the key on and crank engine wont start, very weak spark but when you let off the cranking the ign continues to fire non stop until you turn key all the way to the off position, you can even here it inside the cap buzzing!!! any clues here??
The pick up inside the dizzy reads a magnetic pulse change. If it isn't turning that won't happen. Maybe the pick up is loose or you have a short inside. Repeat the problem with the cap off and watch inside.
Can you see a spark? From where to where? The pick up coil inside the dizzy sends a pulse to the coil so check to see that is tight and has an air gap between it and the cam lobes. Somethig is sending the high voltage from the coil to ground otherwise you wouldn't hear it. That's also why it won't start.
****s changing on me now ARRRRGHH. orig you could see the spark (strong continuous) from the dizzy cap center conductor to one of the spark plug wires without the engine turning over. Now I disconnected the dizzy pick and tried and no spark, then I reconnected the dizzy puckup and now have no sparking at all??????? need to get a new batt in this thing before I go much futher, doesnt appear fuel pump is running either, but baby steps first, prob by prob! also didnt see any blown fuses or links!
chillin014
May 23, 2009 12:37 PM
