Idle problem: 280z FI
Old Aug 15, 2007 | 06:04 AM
Texizgreat's Avatar
Ok lets see if I can explaine this in a some what logical manner.
The car runs fine b4 it warms up, idle is perfect. If I dont take it out and run it it will continue to idle as expected. When I do take it out and come to a stop light take it out of gear the RPM trieds to drop to 0 then catches and reves up and downfor a few seconds. Some times the engine dies most of the time it does not.
Any Ideas?
Old Aug 15, 2007 | 07:49 AM
check your timing. You may be advanced way too much.
If it is advanced too much (should be 10-12 deg BTDC) and you can't adjust the distributor back far enough to bring it within spec then your oil pump shaft was installed one tooth off.
dillenrocha
Aug 21, 2013 02:29 PM
nismodrifterx
Aug 19, 2011 03:37 PM
DrR
Mar 29, 2011 02:08 PM
jooom
Aug 6, 2005 04:35 PM
deckart
Nov 27, 2002 04:20 AM
