Idle problem: 280z FI
Ok lets see if I can explaine this in a some what logical manner.
The car runs fine b4 it warms up, idle is perfect. If I dont take it out and run it it will continue to idle as expected. When I do take it out and come to a stop light take it out of gear the RPM trieds to drop to 0 then catches and reves up and downfor a few seconds. Some times the engine dies most of the time it does not. Any Ideas? |
check your timing. You may be advanced way too much.
If it is advanced too much (should be 10-12 deg BTDC) and you can't adjust the distributor back far enough to bring it within spec then your oil pump shaft was installed one tooth off. |
