Hi Quality engine and transmission seals and gaskets
I need the following parts for my 240z but with Premium high quality standards:
Urethane Bushing kit Steering Rack boots Crankcase gasket or ENgine overhaul gasket kit Rear Main seal / crankshaft Front and Rear transmission Seal Front cover gasket engine Rear differential cover seal Rear differential Seal Should i purchase these seals and bushings in Black Dragon or should i really invest on high end part supplier? if so which one carries all these parts. |
Originally Posted by jalexquijano
(Post 338084)
Urethane Bushing kit Steering Rack boots Crankcase gasket or ENgine overhaul gasket kit Rear Main seal / crankshaft Front and Rear transmission Seal Front cover gasket engine Rear differential cover seal Rear differential Seal Should i purchase these seals and bushings in Black Dragon or should i really invest on high end part supplier? if so which one carries all these parts. However, I have had a good experience with the urethane bushing kit from Energy Suspension. There are lots of vendors selling that particular product. Just curious, is it a requirement you purchase all those parts from the same place? |
Originally Posted by beg3yrs
(Post 338085)
I've never purchased anything from Black Dragon so I can't tell you anything about the quality of their offerings.
I've had good luck with Rock Auto (rockauto.com) for Z parts too. They often give you a choice of multiple manufacturers for the same parts. Give them a try.
(Post 338092)
IF you are looking specifically for Datsun/Nissan OEM parts, the best source for me has been Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com. Remember Nissan stopped building the L24 engine in the early 1980's. True OEM parts may be sparse. If Courtesy Parts cannot find the part, it's likely not available. There are lots of good gasket manufacturers. a vendor like Summit or Jeg's can offer lots of good alternatives to OEM. One piece of advice I came across on this forum concerned head gaskets where OEM Nissan was strongly suggested.
Prothane makes an excellent urethane bushing product. You can buy them directly from Prothane or from several vendors. Make sure you buy kits that come with the installation lubricant included. |
