HELP-she no run right!!!
Old Feb 19, 2004 | 02:04 PM
ITS YOUR THROTTLE POSITION SENSOR!
either it went bad or has water/corrosion in it. Maybe just remove the plug off the bottom of the sensor on the left side of your throttle body. Clean those connections with your toothbrush and some WD-40. (the stuff works good on your teeth too) Do the same to the connections on the bottom of the sensor. Let them air dry for a few minutes. Plug the guy in and rev to the moon!
