headache..
I drove my 76 just a short distance over the past weekend, and I got a headache from it.... It's sad, I want to drive it so badly, but can't. I may just have to sell it. I guess I'll just check over my seals again one more time. :022: If anyone has any other ideas let me know. this car is just sitting in the garage now, while I have to drive a 84 300sd mercedes with 300,000 miles on it! It's soooooo slow! LOL at least I have something else though.
I thought you got it fixed??? You had said something about the fuel injectors sticking...
Which you could have continued this in your old thread so we could read what you had previously done. :D So... Are there any exhaust leaks? (blown / leaking / corroded gaskets, or rust holes in the pipe). Is a cat installed on the car? Does the car currently pass emissions? Does it run good? |
I know I should have kept it going with the other post. so the answers are no, no, yes, and great. I'm going to check again that back seal. I haven't given one last paper test. Now the latch on the hatch has been modified so that the hatch back is down super tight. but maybe just maybe there is a spot where it's not perfect. I never gave it the final paper test after that dumb *&#% mechanic had it. I just stormed out! It's trippy because my z is in really good shape compared to alot I see! and it's been in the garage all the time!
I am going to do the paper test tonight, and take a picture of my new injector connectors. I don't know why I'm so hedache sensitive. I can't smell anything anymore.
here is another idea, get a can of sea foam ok? then unplug a vacume line and have it start sucking in the seafoam a fair amount lik a 1/4 of it and plug the vac lin back in, then rev up the engine it should start smoking like a bitch! this will tell you if you have any exhaust leaks, get a flash light and look for the white smoke, if you only see it coming out the tail pipe, then it MIGHT be a rear seal though i doubt it if the thing doesnt leak in the rain. do this and let us know whats up ok.
Okay, first tonight I am going to do the paper test. I did leak in the rain before this seal.
oh and did you know you can adjust the hatch latch up and down? if yours isnt low enough (where it mounts to the body) then it wont pull down on the hatch hard enough to make a good seal on the rubber stripping so you can try adjusting that down to.
I did that and even made it do it will be tighter than normal by drilling the holes longer on the hook! I feel like I just can't give up!! there is something causing it!! lol maybe there is some tiny exhaust leak... maybe a smoke machine will find it, or is that what the sea foam is for?
Install a catalytic converter... :D
thats what the sea foam is for it will come out as a THICK white smoke at any leaks. oh and EVERY s30 ive owned has a slight exhaust smell in it, maybe your just a sissy ;)
:-) I could be a sissy! but I wasn't always a sissy! I checked the seal on my hatch, and it's super tight. I think between all the printing fumes at work, and the car the way it was, might have made me sensitive for headaches... I don't know. The car doesn't stink anymore though, and I am away from the chems where I work. So... maybe there is another exhaust leak. I'll try this foam stuff out. From the work that has been done on the car, it really is getting tons better. I mean now I really don't smell it. I just need to know what vacuum line should I use?
yes I have thought about it, but how do I do it?
no I'm not sure about the exhaust. the exhaust dude says there is no leak. he checked it 2 times with a stethescope, and fixed what needed fixing. I really don't know anymore, and I'm not making it up on the headache thing. (some people have said to me that it's just in my head! urg. It's not) I don't want to give up on the car... I thought about trying to find someone with a smoke machine, but I don't know anyone, or what to do with one! |
