Fuel injectors not recieving power!
2 Attachment(s)
I think this may be the culprit, what's it look like to you more informed people? This is my first Z so any input would be awesome.
Fuel pump works, fuel gets all the way up to the rail, holds pressure but injectors do not open! Driving me nuts. Attachment 16536 and the ride. Attachment 16537 |
Welcome to ZDriver and beautiful S30!
Have you checked the fusible links? |
All 4 of the fusible links have power running to them!
Under the window washer fluid tank theres a silver little box like thing with a wired connector off the bottom. Thats a dropping resistor for the injectors so they don't get full battery power. Check the connection on that and make sure the wires haven't broken off from it as well.
Its kinda common for the wiring to break off of it. |
Ok I'll be sure to do that! Anyone know what the wires from my first picture go to?
Originally Posted by Solhaven
(Post 324216)
You can see here http://www.classiczcars.com/forums/a...feb14%5E01.jpg |
