Backfire while decelerating (sudden shotgun sound)
Old 12-04-2015, 01:56 PM
jalexquijano's Avatar
I read that backfiring through the carbs is usually caused by the timing being to far advanced. It is trying to fire while the intake valve is still partially open. This is the one that will cause the most damage to an engine, since you not only have the flash, but some of the compression is being released into the intake and back through the carbs.
Im having this same precise problem, My car is a 1972 240z with a Schneider 274F Camshaft and remanufactured SU Carbs by Ztherapy!!! Also have pertronix ignitor and have set the Distributor timing to 11 BTDC. Please note i have also removed all the emmissions crap including the antibackfire valve from the balance tuve. Should i lower the timing to 10 BTDC at idle to avoid the sudden gunshot when decelerating?
jalexquijano is offline
Old 02-10-2016, 09:14 AM
Problem was solved! The exhaust gasket was damaged! No more backfire!
rawblues
12-02-2010 01:59 PM
badboyZ2NV
11-24-2003 03:13 PM
tsibute1
06-24-2003 10:39 AM
justiceboy
04-06-2003 08:44 PM
masashi_z32
08-17-2002 01:07 PM
Quick Reply: Backfire while decelerating (sudden shotgun sound)
