Crank Pulley
Old Oct 7, 2006 | 10:09 AM
sholez's Avatar
Crank Pulley
Novice looking for some help, The crank pulley on my L28 won't stay tight and it comes loose after 5 minutes of ideling. The assembly came apart completely while driving and the only parts that I can find to re-tighten, are the crank pulley bolt and washer
What parts am I missing?
What holds the pulley to the crank and prevents slipping?
Torque specs?
Old Oct 7, 2006 | 01:19 PM
jfairladyz's Avatar
87-116 ft-lbs. (Or 12-16 kg-m if you're going at it metric)
How tight have you been getting it? It's not stripped is it? Or were you just not getting it tight enough?
Old Oct 7, 2006 | 04:09 PM
sholez's Avatar
My guess is that I haven't been getting it tight enough, as it isn't stripped. I just want to make sure that I'm not leaving something out of the equation. I'm guessing that a product like loc tite is a bad idea and that I should just work to tighten the bolt further?
Old Oct 7, 2006 | 05:20 PM
jfairladyz's Avatar
Theres nothing wrong with using loctite on the pulley bolt. But if you cant get the pulley to stay on without it then I wouldn't rely on the loctite to keep it on. It's just a bandaide in that situation as opposed to serving as extra security like it's meant to.
Old Oct 7, 2006 | 06:21 PM
dont forget the large washer that goes on there too, if its missing, it may come loose. and torque is a big help in keeping the bolt in, it is quite tight and kinda hard to get with the stock fan/shroud in place
Trex
Apr 2, 2012 11:16 PM
goodoldZdays
FS: 300ZX (90-96)
Mar 12, 2009 10:36 AM
HybridS130
Feb 6, 2006 08:36 AM
81 Black L28E
Oct 4, 2005 09:51 PM
lance75_280z
Sep 11, 2003 06:28 PM
