ZDriver.com
-   240Z, 260Z, 280Z Performance / Technical (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/)
-   -   Car only reaches 4k rpm (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/car-only-reaches-4k-rpm-35184/)
Bucket280z May 19, 2012 12:19 PM
My 1976 280z is only reaching 4000 rpm on every gear when i accelerate and struggles to get to 5000 & 6000 rpm on nuetral. The guy at Mike Z Shop told me it was a bad AFM and i was wondering if i should buy the afm from the z store for $169.95 with a $400 core charge or pay $250 for him to do it. Can people who had problems with their AFM please help.
hoov100 May 19, 2012 02:42 PM
Why are you going to pay someone $250 to remove four bolts, two clamps and a plug?
And I would bet all you really need is a tune up, generally when the AFM goes out of adjustment it either doesn't run at all, runs REALLY rich or really lean. if you have a multimeter there is a section in the FSM that tells you how to check it.
Bucket280z May 19, 2012 05:30 PM
I know i took it off before i posted the thread it's $250 for the part basicly after i searched around.
So then what could be the cause of maxing out at 4000 rpm
ThaPimpShrimp May 19, 2012 09:16 PM
Hoov suggested a tune up.
Got one of these? Clicky
I suggest you buy one if you don't. Easy diagnoses of multiple things.
XenonS30
You can also download the FSM there.
For starters, check your ignition timing, check/replace distributor cap, spark plugs and wires, check the fuel system. Is it stopping because it's running too lean? Could be a lot of things.
Bucket280z May 19, 2012 10:22 PM
Yeah ill try the tune up cause my car had its head rebuilt and the gas tank cleaned out and it runs fine.
I bought the manuel and have read the xenon link but ima have to recheck.
ZZzzz May 20, 2012 08:24 AM
Have you "rebuilt" your afm yet? it takes all of 15 minutes, a screwdriver and some silicone. could save you some money. check this out-
https://www.zdriver.com/forums/240z-...our-afm-15277/
NismoPick May 20, 2012 01:40 PM
^^^ Excellent post young chap! :023:
Bucket280z May 20, 2012 10:25 PM
Thanks man for this ima try this :023:
