cam question
I bought a cam for my 77 280 and have not installed it yet because I cant afford new rockers, springs, ect. My question is can I install the cam using my existing components
https://www.zdriver.com/forums/showt...hlight=rockers
When you use your already worn rocker arms, they can transfer their wear pattern onto your cam... if there are any impropper wear patterns, or defects in your rockers, your new cam will then receive the same pattern.
As long as the rockers are smooth, you'll be okay. |
As long as the stock coil springs don't bind with the new cam they should be ok too I think. If you are adding a lot of lift, you might need to get new springs to match it. Also I've read that if the camshaft is a regrind, or an all new aftermarket cam with different than stock base circle on the lobes, you might need to buy lash pads to get the proper valve adjustment.
