Anyone know approximate hp of this n/a?
Hey everyone,i have a 78 280z and i just got a new sroker engine and i was wondering if people could guess to how much hp they think it might have in it because im not sure. I am installing it in 2 weeks and would i cant wait. I would say anywhere from 275-300 hp but i dont know for sure may be more may be less.it has...
big bore kit p90 heads 3 angle valve job stage 3 performance cam set f54 l28 block 89mm flat top pistons 240z rods ld28 maxima crank comprtition head gasket new bearings new gasket set new oil pump new water pump new timing chin set coated 3-2-1 header new injectors performance flywheel inlarged throttle body and a cold air intake |
depends, what setup are you using for an ECU?
Welcome to ZDriver! :038:
My guess is 23500437908734628hp. :D |
you had the rotating assembly (not the crank the assembly) balanced properly right? cause if not, it wont make any hp after 4-5k rpms and nothing much about 200hp. thats the trick to the stroker motor.
What is the engine managment and the compression ratio?
Again, I'd agree with Snwy and say maybe 190-220hp at the wheels or upwards of 250 crank horsepower. A ported out factory intake manifold can only flow so much air... and its not really a lot for an NA setup. |
