78 Z differential vs. 81-83 differential?
Old Aug 31, 2006 | 10:52 PM
Fast240Z's Avatar
Do the 78 280Z's use the same differential as the 81-83 280ZX's? I'm not concerned about the gearing, just the type and if a differential from an 81-83 can be a direct swap into a 78 280Z.
Old Sep 1, 2006 | 02:00 PM
veyenyl's Avatar
It's a straight swap.
Old Sep 1, 2006 | 02:33 PM
Darrel's Avatar
Registered Zee Racer
depends on what transmission you have. Manual then yes the r-200 is a direct swap.
Old Sep 1, 2006 | 09:49 PM
theramz's Avatar
I have a present for you...
The later S30's had the diff moved back about 2 inches. You need the mustache bar from a '76-'78, the front cross member and mount from the R200 and the drive shaft from a '74. The R200 means a 200mm diameter ring gear. Plan on replacing the bushings with urethane. The R200 is bullet proof but I broke the mount first time I dropped the hammer hard. Check out my post on rear diff snubber, can't be broken but still isolates the vibration. Solid mounts will vibe your teeth out.
Old Sep 2, 2006 | 12:13 AM
Fast240Z's Avatar
Thanks Tom. Zack had his diff go out on him, and I was going to pull another one and ship it to him.
Old Sep 24, 2006 | 08:10 PM
FubarI33t's Avatar
what's the diff from a 76 280Z 5 speed 2seater. and a 81 5 speed 2seater n/a?
Old Sep 24, 2006 | 08:13 PM
76 280z 5 speed?? isnt it a four speed....but im kinda nick picking it probly doesnt really matter in this case...
Old Sep 24, 2006 | 08:27 PM
FubarI33t's Avatar
well. it had a 5 speed on it. needed a new one. now has another 5 speed on it. i pulled the 5 speed from a 83 N/A. had to swap flywheels. other then that, she bolted right up. And i forgot to put somthing in that post. I was askin the diff in the rear end of those two. just forgot the word Rear End. Oops.
Old Sep 24, 2006 | 08:32 PM
Z Car Barbie's Avatar
User Friendly
https://www.zdriver.com/forums/showt...163#post145163
dan4227
Jun 6, 2012 02:14 PM
Texizgreat
Oct 1, 2007 10:10 AM
MikeZ
May 10, 2007 01:06 PM
bardabe
Oct 6, 2006 07:13 PM
OlderThanMe
Mar 9, 2004 10:27 AM
