ZDriver.com
-   240Z, 260Z, 280Z Performance / Technical (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/)
-   -   78 280z not accelerating smooth (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/78-280z-not-accelerating-smooth-42004/)
Tj Smith Jan 29, 2017 09:44 PM
78 280z stock.
accelerates rough until 3K+ still lacking power.
Timing is set. fuel pressure is good. new coolant temp sender.
new plugs/wires/cap/rotor. compression is 150 in each cyl.
played with adjustment in MAF box. it shifts the power band around a little but still does not accelerate smoothly. pops like it is over fueling.
NismoPick Jan 30, 2017 06:57 AM
Welcome to ZDriver!
Please explain what "good" is?
-Stock timing is 8* BTDC. The L28 really likes 15* BTDC.
-Stock fuel pressure is 30-35psi.
-As for the coolant temp sender, hoping you mean the square connector 2-prong:
http://www.thezstore.com/store/graph...arge113455.jpg
-If you suspect it's running too rich, pull and read / compare spark plug tips. If one plug looks different than the rest, you know there's a problem in that cylinder. If they are all black / wet with fuel then either the AFM or Coolant Temp Sensor isn't working properly.
