60mm Throttle Body Conversion Question
Guest
Posts: n/a
Read this thread, has a lot of good info on it.
http://www.zcar.com/forums/read.php?...9#reply_375707
Guest
Posts: n/a
I have another question.... Hoe much do you have to take off of the intake manifold when you portit? What I'm trying to say is... How much do you grind out? Is it a couple of inches from the opening of the manifold? Or do I have to go all the way through? From end to end.
Guest
Posts: n/a
I have another question... What about the vacum hoses that goes into the TB? Now the fittings for those hoses are smaller then the original ones. Anyone have any suggestions on what to do? Does anyone have pics of their set up? If you can help me out I would appreciate it.
