6 speed trans
are there any 6 speeds that will work in the 240z? and how different is bellhousing?
A quick search for "6speed" will give you the answer. :D
A good read: https://www.zdriver.com/forums/300zx...ns-swap-32281/
(Post 292921)
Things you should consider first:
-The 6speed will have different gear ratios. -The 6speed will have different bell housing. -The 6speed will have different size specs which will make fitting a biotch. -The 6speed will have different output splines, so custom drive shaft needed. And after all that, unless you daily drive on a rural freeway that has 80mph+ speed limits, you'll never need 6th gear. But alas, if you have tons of money, and awesome fab skills, get to it! :D |
