280z not able to start
Old Jul 17, 2008 | 10:26 AM
chall3440's Avatar
i have a 280z and it has fuel in the fuel lines also has spark but when you try to start it, it does not start, thinking its a electrical problem but do not know where to look any info would be helpful. Thanks
Old Jul 17, 2008 | 10:56 AM
When was the last time the car ran?
It may have fuel in the lines, but is there fuel pressure? Can you hear the fuel pump? Are the injectors spraying? Are the spark plug wires in the correct order?
Old Jul 17, 2008 | 11:32 AM
chall3440's Avatar
there is fuel pressure, the fuel pump is working, and the spark plugs are in the correct order, but i do not know if the injectors are spraying but is there a electronic device that tells the injectors to open to let fuel into the cylinder
Old Jul 17, 2008 | 11:59 AM
280zx2by2's Avatar
Haterade by da gallon!
don't be dum like me and switch the fuel lines around.... i took me three weeks to figure that one out.... switched them back after i found the bonehead mistake and it fired right up
did he sask is there an electronic device that tells the injectors when to spray? ok i just hope hes had carbs all his life yikes
and yes... there is, its called an Electronic Control Unit but usually is not the problem unless you have some electrical shorts or crap like that
76280z
Aug 9, 2017 03:40 AM
TonyD11
May 31, 2007 06:28 PM
jeffj2689
Feb 24, 2006 01:55 PM
JustinOlson
Jan 7, 2006 05:33 PM
280zinkansas
Apr 17, 2004 03:54 PM
