ZDriver.com
-   240Z, 260Z, 280Z Performance / Technical (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/)
-   -   280z distributor? (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/280z-distributor-23854/)
280z racer Sep 21, 2007 07:28 PM
280z distributor?
I just got a 77 280z and it needs a distributor, what one do I need to go find?
280z racer Sep 21, 2007 07:45 PM
so what I found is that I Should use a 81-83 zx distributor with the E12-92 module, is the best?
NismoPick Sep 21, 2007 08:17 PM
or... you could use the stock one...
280z racer Sep 21, 2007 08:25 PM
The distributor and starter are gone, can I use the starter off a zx to?
NismoPick Sep 21, 2007 08:36 PM
Indeed....
280z racer Sep 21, 2007 08:40 PM
Yes indeed.
NismoPick Sep 21, 2007 08:42 PM
Are there other parts missing?
280z racer Sep 21, 2007 09:03 PM
The battery.
snwbrderphat540 Sep 22, 2007 12:21 AM
i got a 82 distributor with ignitor ion it for sale if yah wants.
used of coarse but cam off a good running car
280z racer Sep 22, 2007 11:19 PM
I put the starter and distributor on it tried to start her up and she would not start. Then I found that the fuel pump was not on so I ran a power wire to it and it was working. So then I tried to start it agine and she would not start even with starting fluid. So then I tested the fuel injectors for power and there was none. so what dose everyone think?
NismoPick Sep 23, 2007 11:40 AM
What did you use to verify no power to the injectors?
280z racer Sep 23, 2007 09:54 PM
a diod light.
