1972 Radiator issues
2 Attachment(s)
Hello,
Removed the radiator from my '72 240z (Automatic) this last weekend and dropped in an Aluminum 2 core from MSA. The upper water hoses fit perfectly. The lower passenger side A/T fluid line fit's but the passenger side line doesn't line up with the new radiator (it's ~ 6 inches outboard) Beginning to questions if my original radiator is not factory. Anyone had this issue? Attached are pics of the old radiator. Here's the link to the new radiator: Motorsport! High Flow Aluminum Radiator, 70-8/74 240Z-260Z - The Z Store! Nissan-Datsun 240Z 260Z 280Z 280ZX 300ZX ( Z31 Z32 ) 350Z 370Z Parts Thanks Nick |
1 Attachment(s)
Looks like this one to me: Radiator PERFORMANCE RADIATOR 110 fits 74-75 Nissan 260Z
Probably aftermarket OEM replacement https://www.zdriver.com/forums/attac...1&d=1502977657 |
Radiator issues
@ NismoPick ... Thanks! I believe you are correct. Sure wish that driver side fitting was ~ 5 inches inboard. Now I need to have a new line made. All it needs is a 10 inch straight line with the appropriate fittings coming off the oil pan bracket. Thanks!
