Removing the rear strut assemblies: 76 280Z
What is the trick to getting the rear struts out? I know I have to remove the whole hub and everything. I got the locking pin out on the lower a-arm connection but that steel rod with the two large nuts won't budge. Do I need a press or some special tool to get it out? :confused:
It' really tight and corroded in there. I used a piece of steel bar stock, drilled a hole in the end to allow it to fit over the threads. I wet everthing down with penetrating oil and the next day was able to drive them out. I still managed to booger the threads on the pin a little but I repaired them with a small triangle shaped file. MSA sells new ones for $23 each.
strut ass.
or you could remove the inner control bolt's & bushing's.
I have a spindel pin puller! It will pull the pin and save it from damage so it can be reused saving some cash . No pounding and it doesent require the removel of the suspension part from the car. Makes it a easy couple of hour job and if you are going to install ureathane bushings , you can use the tool to spread the part the 1/16'' to allow everything to slip togither. I have it to loan , I just require you to pay the shipping cost both ways and a promise to return the puller when the job is done . Contact me if you need it. If you have pounded on the old pin already this puller WILL NOT WORK . For and example of shipping cost . I shipped it to the San Francisco area from Portland Or and it was $8.00 each way.
i managed to replace the struts on the rear of my 75 by just removing the suspension A-arm from where it pins in to the center cross-member.. i then pivoted the whole strut assebly with wheel hub still intact down and managed to get the strut out of its tower.. but as i recall it required some interesting shifting and fenagling...... but imanaged to do it. i had to remove my halfshafts too, but i had to replace one of them at the same time so it was all gravy. if you do it this way it might not be a bad idea to inspect those halfshafts real thoroughly, and replace if theyre old, and if you can. kinda like doing a water pump when you do a timimng chain, just cuz youre there already, yanno?
When I did mine while I was replacing the springs. I just pulled the half shafts and the whole assembly pulls away from the fender well. The only thing I needed was a 2 inch washer a small piece of cable. I put the washer over the threads and it sits on top of the strut. Wrap the cable around the top of the washer. feed it thru the spring and just pull down. This will compess the strut adn allow you to pull it away from the fender well. It took me about 2 hours to replace all 4 corners on my 78Z. When you pull the half Shafts it allows the A-arm to fall a little further. Remember to watch on the brake lines, they can break under the stress of the pulling. I pulled the rear brake lines to make it easier.
ok guys.... ya, about 5 months ago when I did this I just disconnected the half-shafts and the parking brake cable. I was able to compress the strut with my hand and get the thing to barely clear the fender and swing outward. The first rear strut took 4 hours to figure out. I did the rest of the car in probably 2 more hours of work. The front was much easier.
Since then I have read that removing the inner connections on the lower a-arm is easiest. (as Dareon and Kenneth said) But, one day I'd like to replace all those bushings on the Fairlady... that won't be fun. :( |
its a little off subject, but thats a little peevish; i hate it when someone replies to a problem post that someone else made like six months ago and brings it to the top of the list.... because here i was telling bleachzee how to fix the roblem he's already dealt with, because i was too lazy to look at the date.. i guess we all get peeved when other peoples shortcomings bring up our own shortcomings..
eh, food for thought. |
| All times are GMT -7. The time now is 04:03 AM. |
