bigger brakes
I was told u can put corvette brakes and suspension on a 280z. Does anyone know about this?
yikes.... not without A LOT of fabbing. The most common upgrade is 4-Piston Toyota truck calipers from the 80's trucks. bolt right on to the fronts.
Yea I have the four piston brakes in the front. Where can I find aftermarket rims at? Or do they make the honeycomb rims in 16`s?
Aftermarket rims.... try ebay... or search the web for them... http://www.discountedwheelwarehouse.com/ or http://www.victoriatire.com/ Don't get 16" rims... they aren't that common & tires are more expensive in that size. You do know that to put on modern "Honda style" rims you'll need adapters... right? |
