ZDriver.com
-   240Z, 260Z, 280Z Brakes, Wheels, Suspension and Chassis (https://www.zdriver.com/forums/240z-260z-280z-brakes-wheels-suspension-chassis-126/)
-   -   78 280z drum brake question? (https://www.zdriver.com/forums/240z-260z-280z-brakes-wheels-suspension-chassis-126/78-280z-drum-brake-question-39788/)
Tree_Stump Jun 5, 2014 12:49 PM
I'm new to z cars and just picked up a 280z for $600. The back drum brakes where stuck. I took off the drum and what tearing them apart. I noticed that the wheel cylinders where different and was just wondering for that's normal for the 78 280z or should that be the same part?
Steve260Z74 Jun 6, 2014 03:22 AM
Explain what you mean by different. There are left and right side cylinders.
Tree_Stump Jun 6, 2014 11:05 AM
They are two different parts. I was wondering if they should be the same part?
NismoPick Jun 6, 2014 11:21 AM
Again... different compared to what??? Left cylinder to right cylinder? Different pistons on each side of the cylinder? What?
Help us help you...
Pics?
Tree_Stump Jun 6, 2014 11:47 AM
Yes the right wheel cyilnder compared to the left?
Tree_Stump Jun 6, 2014 11:53 AM
1 Attachment(s)
This is the left one
Tree_Stump Jun 6, 2014 11:55 AM
1 Attachment(s)
And this is the right one
Steve260Z74 Jun 6, 2014 12:52 PM
I erred earlier. The FSM shows a wheel cylinder only like the one you pictured in post #6. I verified part numbers and found only one for the wheel cylinder. This applies to 77 & 78 Zs.
Tree_Stump Jun 6, 2014 01:56 PM
So does that mean the guy before me must have messed around with the drum brakes? I just don't understand why they would be different.
Steve260Z74 Jun 6, 2014 02:57 PM
That's not a bad guess.
zzznuts Dec 30, 2015 08:13 PM
Post #6 (1st photo) is correct for left or right side wheel cylinder on a 1977-78 280Z. The lower photo was the earlier style which used a different wheel cylinder for left and right sides. New 77-78 Datsun Z wheel cylinder:
https://zcardepot.com/brakes/rear-br...80z-77-78.html
zzznuts Dec 30, 2015 08:16 PM
Somewhere in the past an entire assembly may have been pulled off of another car (earlier 70-76). It should work if you replaced all hardware, shoes & wheel cylinder.
