Dash Removal Help
Old Oct 16, 2007 | 10:54 AM
tah's Avatar
tah
Dash Removal Help
Anyone done this?
I removed the trim piece near the windshield (5 phillips screws), the 6 10mm bolts at the front of the dash, the 2 10mm bolts into the console area.
Both vent handle mounts and the steering column bolts. Don't think these really matter, just did them in case.
Seems like somethings still holding the dash in, any ideas?
Thanks in advance............
Old Oct 16, 2007 | 10:58 AM
Did you disconnect the wiring harnesses? Speedo cable? All bolts?
Old Oct 16, 2007 | 11:34 AM
tah's Avatar
tah
All bolts?
Yeah, that's where I wanted this thread to lead.
Like WHAT bolts? Do you know of any hard to find ones?
Old Oct 20, 2007 | 10:40 PM
BoulderZ's Avatar
If you're still working on this: You mentioned 2 10mm bolts in the console area. I assume you mean the center console. But, the dash has two supports around the center console area, one on each side. And each of those has two bolts. It's been about 4 years since I took mine out, but I remember using the How To Restore Your Datsun Z Car book, and the directions on dash removal were good. I still had to wiggle it a little bit to get it out, and that helped show one bolt I had forgotten. If you haven't already, remove the steering wheel and steering column trim, too. Lots more room to maneuver the dash out of there.
Dave
Old Oct 20, 2007 | 10:54 PM
chinesekid's Avatar
i did mines, it was the side with the vents, the radio houseing that whole houseing comes off.. then 4 on top and like 4 or 5 on bottem.. but you gotta remove all your cables too
Old Oct 21, 2007 | 02:00 PM
theres alot of bolts in the S30 dash. very hidden. removed teh trim piece by the windshield and got all those? remove all the uner parts of the dash and the center piece as well as teh center consule. and remove teh glove compartment, all of it. you should be able to find a few more hidden bolts now.
3XAZOWNER
Oct 4, 2006 03:38 PM
Oxide
Mar 23, 2006 05:51 AM
nis88300zx
Jul 17, 2005 06:33 AM
agent_86
Jun 28, 2004 04:55 PM
kalium
Nov 26, 2002 11:17 PM
