MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   ZDriver.com > Cars > 280ZX (S130) Forums
Reply
Thread Tools Display Modes
Old 03-07-2010, 10:58 AM   #1
280zx2by2
Epicly Banned
Timing Chain Slack
Ok I got my head on and everything was going good untill I went to slide the cam sprocket back on and I didnt have enough slack in the timing chain to put it back on.
I understand now that I should have left the wooden stake in to keep the tensioner tight but as of know what can I do to? Im about a 1/4 of an inch away from being able to get the cam sprocket onto the cam but since I have never taken the timing chain cover off I have no idea how the tensioning system looks/works or how to fix it.
I'm really stuck here and have no idea what to do.
EDIT: Chiltons sucks bizzalls on the tensioning system and I can't find my Haynes.
__________________
UY! ES NO FRIO!!!!
280zx2by2 is offline   Reply With Quote
Old 03-07-2010, 11:31 AM   #2
NismoPick
Send a message via MSN to NismoPick Send a message via Yahoo to NismoPick
Buahahha! Did you read this? http://zdriver.com/forums/showpost.p...92&postcount=3
If you took off the cam sprocket and didn't have a block in between the chain, the tensioner popped out and you get to remove the timing cover to reset it... which also means you get to remove the head again, or remove the oil pan, or risk killing the headgasket / oil pan gasket when you re-install the timing cover.
It pays to read the manual.
__________________
www.cardomain.com/id/nismopick
NismoPick is online now   Reply With Quote
Old 03-07-2010, 12:02 PM   #3
280zx2by2
Epicly Banned
I did read the manual but it didn't say anything about the tensioner, just to keep the chain tight against the crank sprocket... Dumbass chiltons I want to kill every single one of them that made that book....
So there's no way to reset the tesioner without taking the head off?
EDIT* But from what I hear you saying I can poshibly get the timing chain cover off just by removing the oil pan?
__________________
UY! ES NO FRIO!!!!
Old 03-07-2010, 12:24 PM   #4
thetremendousti
hahaahaahahahaeha
how many times has it been mentioned that while removing the head or timing chain to ALWAYS USE THE SACRED WOOD CHUCK!!!!
you could try the oil pan but that tension is really hard to reach, not impossible but...imo just read the haynes next time, hell read any thread about head removal....hahahahahhha sucks for you man
__________________
no more zs for me
thetremendousti is offline   Reply With Quote
Old 03-07-2010, 12:25 PM   #5
SHADY280
nope youre pulling stuff apart, there is no half way about fixing it now you may be able to shine a light down to confirm it poped out, but it most likely did.
__________________
CANADIAN ZEDS GO FASTER
(COLDER AIR!!)
http://www.cardomain.com/ride/2462796
Quote:
Originally Posted by lww
Shady is correct... as usual...
SHADY280 is offline   Reply With Quote
Old 03-07-2010, 12:32 PM   #6
280zx2by2
Epicly Banned
Quote:
Originally Posted by thetremendousti View Post
hahaahaahahahaeha
I have read them, just never read where there was emphasis on the wooden steak's importance of keeping the tensioner in place, I thought it was just to keep the chain on the crank sprocket...
Quote:
If I can see it wobbling and can push it back an forth with a screw driver is it popped out?
Im reading my half assed chiltons book and im thinking about just pulling the pan and timing cover w/o pulling the head.
anyone know what size the crank pulley bolt is? Ill have to go buy a socket that big lol
__________________
UY! ES NO FRIO!!!!
Old 03-07-2010, 03:12 PM   #7
hoov100
If I remember, it was only like 22mm, as for pulling the pan or head to remove the timing cover, remove it and cut the front of the oil pan gasket and just silicone the **** out of everything and it shouldn't leak.
__________________
./ ./,====="---> <"))))>< .·`·.><(((º>..· ><(((º>
/_/
hoov100 is offline   Reply With Quote
Old 03-07-2010, 04:43 PM   #8
280zx2by2
Epicly Banned
Quote:
Idk about the last part but 22mm sounds right, Couldn't I just snake the new gasket around the baffle?
Im so pissed that I was less than a 1/4 of an inch away from being done and now it sounds like Im going to have to spend another couple weeks on this slow pos...
__________________
UY! ES NO FRIO!!!!
Old 03-07-2010, 05:10 PM   #9
hoov100
I tried once, its too tight of a fit to just jiggle it in there.
__________________
/_/
Old 03-07-2010, 05:27 PM   #10
snwbrderphat540
Send a message via AIM to snwbrderphat540
just do it over ground up. these are super simple motors with just a retarded tensioner. shit every Z i've owned i've pulled the motor on, its takes 2 hours. i understand if you cant do that but with the radiator out and the hood off you have plenty of room to do the timing chain crap.
speaking of which, i should start piecing together a new timing chain setup for my turbo motor. i will be having fun with that lol.
__________________
but I'm truly a ricer...
snwbrderphat540 is offline   Reply With Quote
Old 03-07-2010, 05:48 PM   #11
280zx2by2
Epicly Banned
Well don't call me crazy but... Cut the new gasket and slide it in? simple as that? little extra silicon around where you cut it and bam! youre done.
I don't even have a garage, im doing this outside on a tarp with some ramps... And I don't exactly have a hoist to take the engine out with.. can I borrow your dads? Haha good luck with the turbo build though.
Someone please buy this for me and send it to my house... hell, Ill even pay for the shipping
__________________
UY! ES NO FRIO!!!!
Old 03-07-2010, 07:04 PM   #12
snwbrderphat540
yeah that tensioner setup is nice... me wanty myself, but soooo much money for a tensioner lol. and bitch that hoist is both of ours!!!! split even steven and the engine stand is mine alone. so suck it haha.
__________________
Old 03-07-2010, 07:11 PM   #13
thetremendousti
your going to want a 27mm for the crank pulley (i got a 1 1/16" same thing)
22mm is 02 sensor....
__________________
no more zs for me
Old 03-07-2010, 09:20 PM   #14
NismoPick
2by2... if your oil pan gasket is in good shape, you can loosen all the bolts on the oil pan & lower the front just enough to slide the timing cover back in place. If it's the stock one, don't count on it working.
You COULD shloob the crap out of the timing cover to oil pan flange with RTV, but that's not a great idea as that may allow excess RTV to get into the oil.
__________________
Old 03-08-2010, 12:53 AM   #15
Cali79zx
Cali79zx's Avatar
Well, Im glad to see that I'm not the only one that did this. lol. unfortunately your probably gonna have to take the front cover off to back the tension off. Thats what everyone I've talked to said, so that's what im doin at the moment. Let me know how it goes and good luck =)
EDIT: The crankshaft pulley bolt is 27mm. Trust me, I bought like 3 different sizes to get the right one. hahaha
Cali79zx is offline   Reply With Quote
Old 03-08-2010, 07:12 AM   #16
thetremendousti
Quote:
just use a ruler next time hahahahaha!!!
okay so i had a dream and i just woke up from it, okay so along with some really ridiculous stuff part of my dream consisted of opening my valve cover and finding out that I had slack on both ends of my timing chain, and when I pulled them I heard the tensioner lose slack and it was still hanging on by a thread and when I went to go try to fix it, it was like defusing a bomb and it came fully apart it was a terrible dream completely inspired by this thread
__________________
no more zs for me
Old 03-08-2010, 12:45 PM   #17
280zx2by2
Epicly Banned
Haha your trial & error, my benefit. Thank you lol and Ill keep you updated.
Um, Kinda sounds like you need to take a break from working on your car. haha
__________________
UY! ES NO FRIO!!!!
Old 03-13-2010, 02:03 PM   #18
280zx2by2
Epicly Banned
__________________
UY! ES NO FRIO!!!!
Old 03-13-2010, 02:30 PM   #19
NismoPick
Lesson learned eh?
__________________
Old 03-13-2010, 02:54 PM   #20
Cali79zx
Cali79zx's Avatar
That is almost exactly what mine looked like when i got the timing cover off. except the tensioner was bent down lol. the spring in the tensioner was jacked up so I had to get a new one.
Old 03-13-2010, 04:18 PM   #21
280zx2by2
Epicly Banned
Lesson learned eh?
Soo many lessons learned... you have no idea. well maybe you do. haha
__________________
UY! ES NO FRIO!!!!
Old 03-13-2010, 04:57 PM   #22
Cali79zx
Cali79zx's Avatar
oh trust me, I learned and I'm pretty sure I have an idea of just how many you learned too hahaha
Old 03-14-2010, 09:41 AM   #23
280zx2by2
Epicly Banned
Well I figured Id do this right and get my timing where it should
So the best thread I have found for cam timing is Shady's, I sent him a PM but he hasn't gotten back to me.
But my questions are in regards to his thread about timing chain stretch.
http://zdriver.com/forums/showthread...+chain+tension
When he says the mark should be to the left, is this that left? Or is this the wrong way and my chain has too much slack?
And if it is as for the directions to fixing the issue what does he mean by "Remove the cam bolt, pump eccentric and cam sprocket and advance it to the next position"?
__________________
UY! ES NO FRIO!!!!
Reply
Tags
280zx, cam, chain, removal, slack, tensioner, timing
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2010 ZDRIVER.COM All Rights Reserved.
