MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   ZDriver.com > Cars > 240Z, 260Z, 280Z (S30) Forums > 240Z, 260Z, 280Z V8 Swaps
240Z, 260Z, 280Z V8 Swaps Chevy / Ford / Nissan V8 Motor Swaps
Reply
Thread Tools Display Modes
Old 03-13-2006, 07:58 AM   #26
Phantom
FWIW - I have a 280Z with an LS1 / T56 combination in it. It is a fully loaded daily driver so it weighs in at a full 3,000 lbs. When I started the conversion the car weigh 1400 lbs on the nose and 1400 lbs. on the tail with 3/4 tank of gas. When I finished it was 1400 on the nose and 1430 on the tail. The extra 170 lbs came from strut tower braces, a 4-pt roll bar and extensive interior and sound system work. When I finished, it weighed 1440 on the nose and 1560 on the tail with a full tank of gas. Also, the driver's weight distributes 3/4 to the rear wheels and 1/4 to the front. All the weights were taken on a certified truck scale.
Yes - the LS7 will mount exactly the same as an LS1 so the JCI and JTR kits can be used to install it.
The LSX Z can be made to handle every bit as well as a Bob Sharp car and will have obviously a lot more HP which will allow throttle steer in the corners.
In a straight line, again if it's configured properly, it can get down into the 10's. Some guys are now starting to push toward the 9's. It's all in how well you sort it out and how much money you have to spend. It will, however, cost you less than a new Z06 or Lambo.
Phantom is offline   Reply With Quote
Old 03-14-2006, 12:02 AM   #27
duowing
But it's as everyone else said. The main idea is that you can't just throw this engine into your car and expect it to beat out a lamborghini in all aspects. It will require alot of work. Reinforcing the car in all areas, etc. It's no longer your every day Z car with a big engine. It's a drastically modified car and about the only thing that keeps it a Z is the fact that the chassis is still that of a Z. There's really nothing Z about it anymore. You won't have the classic Inline-6, you probably won't have half the luxuries, and a good portion of the car's rear is now taken up by the roll cage. Don't get me wrong. It'd be completely awesome to even have a Z that insane, but it's just not a Z so much. It all really depends on the person. I'd rather build a quick Z that keeps itself relatively similar to what the car started as, and leave the super fast 1/4 and track runs to the newer cars designed to do it with the big HP numbers in mind.
__________________
1976 280Z 5-speed
1983 280ZX Turbo Z31 ECU/MAF Swap
1987 300ZX Turbo 5-speed
duowing is offline   Reply With Quote
Old 03-14-2006, 07:00 AM   #28
Phantom
Go to www.cowtownzclub.org and look at the red 280 in the gallery section. That is my car. The only difference between it and an LS7 Z is the the number. Mine has an LS1. It has everything else. I'm sorry - but it sure looks like a 280Z to me even though only "the chassis is still that of a Z". It still seats two people comfortably and has a killer sound system and great AC.
Oh yeah - I forgot to mention - it is my daily driver. It takes me to work and back every day so it is extremely reliable too.
Old 03-14-2006, 09:14 AM   #29
entropy31
The Cake Is A Lie!
entropy31's Avatar
yeah, but is it a lambo killer? didnt think so.
__________________
Admin
'87 Metallic Grey NA auto "Sold"
'95 Arctic White Pearl Slicktop
'85 Honduh Stuper Civic 4wd Wagon (Legendary Snow Beast!)
Quote:
Originally Posted by RodMoyes
You are a freaking GENIUS!!!!
Quote:
Originally Posted by thxone
My god E...are you nuts???
entropy31 is offline   Reply With Quote
Old 03-14-2006, 09:22 AM   #30
Phantom
Only had a chance to run a Lambourgini once. I beat him - and that was with the LS1, not an LS7 which would be a direct bolt-in replacement. Sorry to disappoint you.
Old 03-14-2006, 09:29 AM   #31
NismoPick
Send a message via MSN to NismoPick Send a message via Yahoo to NismoPick
Quote:
This your dyno sheet??
__________________
www.cardomain.com/id/nismopick
NismoPick is offline   Reply With Quote
Old 03-14-2006, 09:33 AM   #32
Phantom
Yep - sure was - from two years ago before I made some mods. Thanks for posting it. Sure like how broad that torque curve is.
Old 03-14-2006, 09:41 AM   #33
NismoPick
is that the LS1 or LS7? I thought LS7's were rated @ 400+ hp stock (flywheel).
__________________
Old 03-14-2006, 10:06 AM   #34
Phantom
LS1's were rated form 305 to 405 HP at the flywheel depending on the year and model vehicle they were in. LS2 is rated at 400. LS7 is rated at 505.
My LS1 came from a supposedly 320 HP Z28 but, with K&N intake & headers it mathed out to 365 HP at the flywheel assuming a 15% drivetrain loss. Only thing that really counts though is the wheel HP because that is what is really getting to the road and accounts for all the drivetrain parasitic losses. The LS1's were found in the C-5 Corvette, '98 & newer Camaros & Firebirds, the Cadillac CTS-V, and the new GTO through 2004 or 5. LS2's are found in the C-6 Corvette, the CTS-V, and the GTO. I'm not sure what the Cadillac roadster with the retractable hardtop is running now. It started out with a Northstar but I think they have one with a V-12 coming out? I just don't keep up on all the GM models that much.
Old 03-14-2006, 10:50 AM   #35
RodMoyes
Half Mod / Half Rod!
RodMoyes's Avatar
Uhembullshituhem... No seriously though... IF you did "Run" a Lamborghini, then I am assuming you're talking about a 1/4 mile drag race... BFD!
Get over yourself now... There's only about a thousand other cars that will take out most Lambo's in a drag race...
Funny thing about Lambos most dipshits don't know... THEY ARE NOT A DRAG RACING CAR FOR CHRISTS SAKE AND THAT IS NOT WHAT THE CRUX OF THIS THREAD IS... PULL YOUR HEAD OUT ALREADY.
Chase that same Lambo through a nice twisty mountain road and you'll most likely die trying to keep up
That would make him the lambo-killer... get it? killed by a Lambo?
ARGH! If you want to argue a point in the future, try arguing the same one that the thread is based on ok?
Rod.
__________________
RodMoyes is offline   Reply With Quote
Old 03-14-2006, 11:42 AM   #36
Phantom
What amazes me is the tremendous effort everyone is making to claim that there is no way the Z car can be modified to run with a Lambo. The resistance to even think that it could be done is incredulous! Does it require extreme measures? Yes it does. Would the Z then be able to stand up to a similarly modified Lambo - not a chance. Could the Z run a flying mile against it - not a chance - the S30 just doesn't have the aerodynamics to get the job done. Not sure about the Z32 or 33. I know too many people that have Z's that could run on a road course with a Lambo heads up. I know a guy who ran a Datsun 510 heads up against a group of modified Vipers. Heck, I ran on the combined infield & oval course at Texas Motor Speedway against a Ferarri Testarossa 512. Did he beat me - he sure did! But I had stock Z brakes and suspension at the time. Would better brakes and suspension made the difference? Nope - the driver of the car way outclassed me - but he would have had to work a lot harder. If I'd had an LS7 in the car - probably not then either because the Ferarri dirver was the better driver.
Heck, I know what you mean about drag racing - my son beat a Diablo in a stock '83 Sentra. The Diablo driver stalled on the launch. But then a victory is a victory - isn't it? I'll bet you'd tell your buddies about beating another hot car even if the driver screwed up and missed a shift or a corner - right?
Old 03-14-2006, 12:31 PM   #37
NismoPick
I think your S30 is quite a site, and I'm sure it's nuts to drive, and I totally respect your work, but I think along the lines of what Rod was saying... All of what you just said, sounds just like what the teenage ricers say these days... which gets annoying really really fast. "I beat a Corvette!" "I beat a Viper!" "I can go 200mph in my Civic!" "I can outrun any car out there"
It's just comments like that, that makes sports car enthusiasts want to jump all over ya.
__________________
Old 03-14-2006, 12:32 PM   #38
entropy31
The Cake Is A Lie!
entropy31's Avatar
good job. drag race. whoopeeeee. that does not make it a lambo killer. i know this has already been covered, but what i meant by lambo killer is something that could hang in all aspects with the lambo, including comfort. i'm sure your car is a beast, but it cannot compare to the lambo. sorry to dissapoint you.
__________________
Admin
Old 03-14-2006, 03:52 PM   #39
jfairladyz
jfairladyz's Avatar
I think the point here is a Z in stock or mildly modded, or hell, even heavily moddified form can not hang with a lamborghini. This is true beyond a shadow of a doubt. Of course if you figure the amount of work and money into the Z to put it at par or possibly above the lambo then it would cease to even be a Z. The body may still slightly ressemble a Z but that doesn't make it a Z. And now we're talking a full on race vehicle instead of a Z that was originally designed for the street. Meanwhile homeboy in the Lamborghini is still laughing, whether he loses or not, cause he had his air conditioning on in his all leather cabin bumping his stereo while sitting comfortably next to two hot supermodels crammed into his one passenger seat while you're sitting in a puddle of sweat by yourself picking up all the teeth your suspension rattled out of your mouth so even if you did win you wouldn't want to laugh with your now ugly mug
I'll take a lamborghini before I ever dreamed of making a Z that could compete with one. I'll keep aiming for SS's and Cobras for now
__________________
jfairladyz is offline   Reply With Quote
Old 03-14-2006, 06:02 PM   #40
RodMoyes
RodMoyes's Avatar
^ What a great way to put it!
Rod.
__________________
Old 03-14-2006, 10:14 PM   #41
ZETA
Send a message via Yahoo to ZETA
My Festiva can kill a lambo,I think my Z will kill both easy.
http://videos.streetfire.net/player....2-8A06AD790279
ZETA is offline   Reply With Quote
Old 06-15-2006, 02:33 PM   #42
Stu Korpela
I am right now installing a 383 stroaker 460 HP v8 into my 280Z with Ferrari body. Light and fast Just hope the crappy Z brakes can stop it. I'll let ya'll know.
Stu Korpela is offline   Reply With Quote
Old 06-15-2006, 05:24 PM   #43
ASA240z
ダットサンマニアック
ASA240z's Avatar
Here so states that I found about the lambo Murcielago '02.
Zeta, like evey other person in the thread has stated, your car can't be called a "Lambo Killer" if it just beats it 1/4mile. A real "lambo killa" would have to best the car in just about anything. Such a car brings me to the thought as to why in the hell someone would dump so much money in a Z to even mention the idea that a Z is comparable to a Lambo. Seriously, why would anyone compare a fixed up "poor man's sports car" to a f'in Playboy spagetti burner...
IMO 1/4 racing is probably the boringest racing there is, next to nascar. Like Rod stated, the lambo IS NOT MADE FOR STRAIGT LINE, although 11.7 1/4 is pretty damn good. Even if some one here had a Z fast enough to compare with a spagetti burner, there is no way a "stock" looking Z would compete in a twisty road. Your Z would barley allow you to read the damn lincense plate on a Lambo, LOL
To those who claim to have a "LAMBO KILLA", read the stats and show us "Na sayers" that we're wrong...
http://www.supercars.net/cars/982.html
As for those who make BS claims, a bitch slap to ya all .
Later,
Allen
__________________
ダットサン 240Z
ダットサン 280ZXT
トヨタ 4Runner
ASA240z is offline   Reply With Quote
Old 07-17-2006, 01:07 AM   #44
nick's81240zx
nick's81240zx's Avatar
i have read most of what everyone has said and i think that you can make a "lambo killer" out of a z/ zx its all about the money!!!!!!!!!!! I have been working on my friends 240z scca (I.T.S) race car for about 3years and if we repainted it (to make it look like a street car again) and put a ls7 in it i would smoke a lambo (not 1/4mile on a track) what he did to all the suspention is they took out the oem parts and remade them into tube alumium parts (so there are lighter and stronger) he has put 10's of thousands of dollars into it but its still a z and is still a una-body z. there are pics of the car in the gallary if any of you dont beleive me its not hard to do just takes time and money!!!!!!!!!!!
but why would you do this to a z go buy a lambo if that is what you want!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
__________________
Car's I own,
73 240z (my baby)
82 280zxt (parts car for 240z)
81 280zx 2+2 GL t-tops (parts car)
93 pontiac sunbird 3.1 (blown-up)
nick's81240zx is offline   Reply With Quote
Old 07-17-2006, 02:05 AM   #45
RodMoyes
RodMoyes's Avatar
^... And after all of that...
Sorry, It's still NOT a Lambo Killer.
Ask yourself this question:
If you rolled up to a group of hot supermodel looking chicks outside a club in a 240Z or a Lambo... Which car would give you the best bet at even getting one of them to talk to you?
Case closed.
Next issue please.
Rod.
__________________
Old 07-17-2006, 05:18 AM   #46
ASA240z
ダットサンマニアック
ASA240z's Avatar
Case closed.
Next issue please.
Rod.
What he said...
__________________
ダットサン 240Z
ダットサン 280ZXT
トヨタ 4Runner
Old 07-17-2006, 03:07 PM   #47
veyenyl
veyenyl's Avatar
If it's a clean 240Z, they might think it's a vintage Ferrari. What do supermodels chicks know
__________________
'71 240ZT
Modern Classic
http://www.cardomain.com/ride/2413227
veyenyl is offline   Reply With Quote
Old 07-17-2006, 03:26 PM   #48
BlackCrow
Banned
BlackCrow's Avatar
Usually super models chick now nothing about cars so i wouldent be suprised.
BlackCrow is offline   Reply With Quote
Old 07-19-2006, 11:49 PM   #49
BlackCrow
Banned
BlackCrow's Avatar
Hey when you guys mean a z car can never beat a lambo do you mean just the S30?
Old 04-24-2009, 03:54 PM   #50
JPerkins
JPerkins's Avatar
Send a message via AIM to JPerkins Send a message via MSN to JPerkins Send a message via Yahoo to JPerkins
woo hoo, dead thread! Posty McPosty Post. I am really glad i wasn't around for the time this thread would have held a spot on the front page.
__________________
Poli-derived from the greek work Poly, meaning much or many.
tics-plural form of the coon-ass word "Tic" meaning little blood sucking insect.
http://s242.photobucket.com/albums/f...80zxt/?start=0
JPerkins is offline   Reply With Quote
Reply
Tags
240z, 350z, ca, hayward, killa, killer, lambo, ls1, ls7, motor, mounts, replace, rocket, shop, supercar, swap, turns
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2000 - 2009 ZDRIVER.COM All Rights Reserved.
