need help
need help
i just picked up a decent 90 Nissan 300ZX N/A Aztek Red, 160,225 mi, ABS, PB, PS, Tilt, Air, PW, Air Bags, 2 Dr, 6 Cyl, Alarm, All Power, AM/FM CD, Auto, Cruise, Multi CD, Fully Loaded , SOHC, NON turbo, 2 Seater, Glass T-Tops ,GReddy SP Exhaust, JWT PoP Charger, Unorthodox UD Pulley, KYB AGX shocks, JSpec Fairlady Z Tail Lights, Rebuilt Transmission Damage: Headlight, Fender, Hood (Truck backed into it), Worn Leather Seats for 1000 is this a good deal and the car doesnt run but the guys said it was the crank angle position sensor would that stop it from starting it turns over but doesnt want to start o and i need to get a headlight fender and hood doesn anyone know where i can get some lmk asap wanna get htis car going
Welcome to ZDriver!
We have a MUST READ Sticky on this subject: https://www.zdriver.com/forums/300zx-z32-tech-tips-273/general-z32-info-8434/
1. the s30 and z32 chassis where the only z's to not have tilt steering columns.
2.the vg30de is not a SOHC motor, as when you have to do the timing belt you will wish it was.
but anywho, do the link, check the codes, then go through the EFI harness as its usually the culprit...
buying a Z32 that has a mystery as to why it doesnt run at the moment is something i would never ever do.... so many possibilities. but yes a crank angle sensor is a pretty important (and not cheap if i recall) part on a car that it needs to run. auto trannies are a pain as well
