How to fix a "locked up" engine
Old 11-13-2007, 04:52 PM
nikitenko91's Avatar
i bought a 300zx and the guy said that the engine is "locked up" when i try to start it, it makes a loud grumbling noise. i see that the timing belt has been changed.
nikitenko91 is offline
Old 11-13-2007, 05:25 PM
The Cake Is A Lie!
entropy31's Avatar
1.) remove engine.
2.)find replacement.
3.)install replacement.
what do you mean by "locked up"? will it spin at all? what do you mean by "grumbling noise"? we will need more info to help.
entropy31 is offline
Old 11-13-2007, 05:41 PM
thxone's Avatar
Unless it was a bad felony, I would post bail and see if you can get the engine released....or I would find a locksmith and see if they (he/she) could un-lock the engine. My friend had an engine that "froze up" my mom told him to throw some hot water on it.
thxone is offline
Old 11-13-2007, 06:23 PM
I'm a Registered User!
SpeciallySpiked's Avatar
Does it turn over? Is it locked up from water? etc
SpeciallySpiked is offline
Old 11-13-2007, 06:47 PM
caught the z fever
b300z's Avatar
b300z is offline
Old 11-13-2007, 07:54 PM
yea it turns but when i try to start it, it is really loud and the whole car shakes it sounds like its having a hard time turning.
Old 11-13-2007, 08:02 PM
The Cake Is A Lie!
entropy31's Avatar
does it have oil in it?
Old 11-13-2007, 08:24 PM
turboZ87.300's Avatar
LOL
Drain the oil and see if you get silver flakes in it...or if you get big pieces, then it's the bottom end... hope this helps...
Year,... NA, turbo???
turboZ87.300 is offline
Old 11-14-2007, 05:53 AM
yea it has oil. ill try to drain the oil today and see if it has the flakes.
Old 11-14-2007, 03:22 PM
when i turn the engine with a ranch it turns but then at a certain point i cant turn it no longer it gets stuck and when i turn it the other way it turns again but then also gets stuck after a while.
Old 11-14-2007, 03:27 PM
That means it has compression. Take the spark plugs out.
NismoPick is offline
Old 11-14-2007, 04:25 PM
lol! ^^^^ oh you... you sound like you need to do research. take teh plugs out yes. it will still be a little tough with the cam and springs. but still. what are you rotating it with? and where?
snwbrderphat540 is offline
Old 11-14-2007, 07:49 PM
i rotated the crank shaft with a ratchet
Old 11-14-2007, 07:50 PM
its not that its hard to turn it, it gets stuck that you cant turn it no more.
Old 11-15-2007, 04:54 PM
Pr0n Addict
KasbeKZ's Avatar
seriously, take the plugs out. if it still is hard ot turn then its a major problem. the best way to narrow down is take the timing belt off and try spinning each cam and the crank separately. the stiff one is the problem.
and "ranch"? is that a thick accent coming through in your typing?
KasbeKZ is offline
Old 11-15-2007, 08:26 PM
91zxtt's Avatar
How exactly would having the plugs removed make it easier to turn it over manually? You really shouldn't rotate the cams separate for the crank. It could cause the valves to hit the pistons; which is bad. If the engine is binding up when you turn it over manually, then there are some major problems.
91zxtt is offline
Old 11-15-2007, 08:46 PM
reddzx's Avatar
valve hitting piston, broken connecting rod, just some of the more drastic reasons. CHECK OIL FOR METAL PIECES FIRST!!!!!
reddzx is offline
Old 11-15-2007, 10:25 PM
thxone's Avatar
Having an open hole in the combustion chamber will allow air to escape each cylinder as the piston moves up the piston chamber...I.E. less resistance when turning by hand. If the rotating assembly will only go so far in either direction with the plugs out then it is a safe bet that something is broken...could be a broken and jammed timing chain (take off valve cover and see if the chain is still in one piece) Could be a broken valve stuck in one of the combustion chambers. Could be a busted connecting rod. The car could be in gear. The starter might be jammed.
thxone is offline
Old 11-15-2007, 10:44 PM
The Cake Is A Lie!
entropy31's Avatar
timing chain
belt. not chain.
Old 11-15-2007, 11:30 PM
thxone's Avatar
belt. not chain.
I am way to used to posting in the 280ZX area....belt huh...ok so scrap that idea
thxone is offline
Old 11-16-2007, 04:52 AM
taking out the spark plugs just makes it easier to turn. but it still gets stuck in the same places as before
Old 11-16-2007, 08:10 AM
If the motor can turn about 3/4 of a turn, then most likely the piston is hitting the valve... if it only turns 1/8 or so, then most likely it's a bearing or the timing belt it out of time... time to take it a part... take the belt cover off and look of the timing marks and look for a part of the belt missing... Good Luck
One more thing... look at the plugs... see if one or more of the plugs has damage to the tip...
Old 11-16-2007, 12:21 PM
its turns about 3/4, i have the timing belt cover off every thing looks good their.
Old 11-16-2007, 04:57 PM
Sounds like the piston is hitting the valve... if the valve is bent, it will not close all the way, then the piston comes up to the top and hits the valve, that's why the motor wont turn 360%... now you have to find out what side...
Old 11-16-2007, 07:17 PM
What I said,
in more simple terms...
No spark plugs = no compression. No compression = no sealed chamber of air to compress. No sealed chamber of air to compress = easier to turn.
Whew!
I take it you've never done this before???
Quick Reply: How to fix a "locked up" engine
