High idle problem: Another solution
So I encountered the dreaded high idle problem on my Z. I went after the IACV and the AAC. A little tedious but logical. Both checked fine, cleaned them and reinstalled. No change. This was high idle when WARM so when I unplugged the IACV idle would return to normal, plug it in and 1800RPM. After spending half the day doing this based on the FSM and forum fixes, I went to troubleshooting mode. Checked TPS: slightly out at .328V and 3.82V. Reset to factorytolerence of .45V and 4.5V respectively. No Change.
So what powers the IAC? The coolant temp sensor! Unplugged it and saw nothing but green corrosion. Cleaned contacts and plugged it in....instant fix!
I remember from the Bosch L-Jet school: If it's a Bosch component, go back and check something else. Check the coolant sensor first.....DUH!
Often the obvious gets overlooked....
madkiwi
06-06-2015 07:40 AM
DrR
03-29-2011 02:08 PM
S13Sean
09-21-2003 05:40 PM
