My truck doesn't close
Hi i'm new here and i just recent bought a 32z and i dont know why my truck wont close all the way down tight i dont get it. does anyone have any input on this or a link that i could get some help on that would be great thank alot.
Originally Posted by xzAZNloner300zx
Hi i'm new here and i just recent bought a 32z and i dont know why my truck whole close down tight i dont get it.
well first off better english helps if you want help. if your post is very hard to read most will just give up and look away. more info on what your hatch is doing would help too.
also look in the z32 section and look at riz's information thread (it a sticky and close to the top) and there is an online manual in there somewhere start there.
btw its
hatch not truck
z32 not 32z
won't not whole
recently not recent
yea it the hatch. so here is the problem when i lift up the lever to open the hatch it doesnt pop up or anything it i need to keep the lifting up the lever while someone open the hatch for me. it a pain in the ***. so it the latch than is that what everyone saying???
i have the same problem. what that is is that the seal for the hatch has become compressed and the hatch sits too low. what i did was cut a slit in the seal right in the middle where the latch is (on the car side. not the hatch side). a very smal slit mind you. maybe an inch or so. then i fed in some stiff rope to hold the hatch up a little bit. maybe 1/4 in rope. this hods it up with enough tension that i don't need to lift up on it to open it.
but, your first post said that it wouldn't close... then your second post said it wouldn't open.... you really need to be a little more intentional with your words.
yes i'm asian i'm sorri i forgot to give all the info about my problem. And it both it wont close correctly and it wont open correctly. sorri about my english sometime when i'm into something i dont really check what i wrote please be dont be mad at me ok i dont really write in alot of forum.
Originally Posted by KasbeKZ
where? to build up the seal? that's a bad idea. it would let a lot of water in that way. that's why i put something in the seal instead of on top of it
