leaking steering fluid? need new steering rack?
Old 12-12-2005, 05:35 PM
graverhead's Avatar
1990 Nissan 300zx (stock)
Ok so the past 2 weeks I've had to consistently fill my steering fluid. It now drains almost immediately... as though there's a big ****in hole at the bottom of the reservoir. I checked the tubing (in plain sight) and it's practically soaked. I tightened the the little clamps in case they were just loose.
All of this was an exercise in futility.
I took it to a local shop today and they said that I need a new steering rack and pinion and that it's going to cost me $1,000. Are there any cheaper solutions or should I just bite the bullet?
graverhead is offline
Old 12-12-2005, 08:33 PM
confuzed member
emo236's Avatar
well, the fluid could ruin your alternator. to your leaking issue, why not remove all the power steering components and replace all the hoses, etc. Check it all and make sure to fix the leaks in that area. your leaks are probably from the pump/reservior, not the rack since you said you already found a hole in your reservior! I would guess that the hole is the major attributing factor and would get a new reserviour.
emo236 is offline
Old 12-13-2005, 04:17 AM
Jack Of All Trades
CanyonCarver's Avatar
I agree with emo. I wouldn't trust the place giving you the $1k estimate. Start with the rubber hoses that are known to leak over time. I had to replace a leaking return hose myself. It cost $8. The pressure hose can be kind of expensive, something like $100 or so. I believe you can replace the seals in the rack if necessary.
A rebuilt replacement rack should be in the $300 range. If your steering feels tight, relatively (not power steering wise), like there's no play or slop between when you turn the steering wheel and the front wheels turning, then the rack is prolly not worn out. An example of worn steering is generally any old ford pickup where you can turn the steering wheel 1/4 turn in either direction and the front wheels don't move.
CanyonCarver is offline
Old 12-13-2005, 09:00 AM
graverhead's Avatar
Thanks guys. I really do appreciate it.
I'm gonna go pick up the car from the shop and try to fix it myself (with a friend's help) and then when I fail, I'll take it back to the shop and pay out the $1,000. At that point, I'll be selling the car. I can't afford to run this thing anymore. :-( Full time college, part time job... just not working. I'll end up getting a Civic or a Passat, probably the Civic though cuz it's less expensive to run.
I'll miss my baby. *cries*
Old 12-14-2005, 12:39 AM
RaZx's Avatar
Well, I'm having a problem with my steering also...I've been told it's the rack. Fluid stays full , but there is no sloppiness to the steering. When I turn, the wheels turn, It's just really hard to do considering I have no power steering for one reason or another.
Should I assume that the mechanic WANTS me to pay more for the rack, but it may not be necessary? Should I try to change out the power steering pump or anything else myself first before paying to have the rack replaced?
RaZx is offline
Homeboyx
04-19-2013 09:09 AM
hoov100
07-18-2007 01:00 AM
thxone
11-19-2006 09:33 AM
Cw2435
11-04-2004 08:06 AM
goodtaste4all
01-27-2002 05:13 PM
Quick Reply: leaking steering fluid? need new steering rack?
