1986 z31 turbo ac condenser fan
any members been thru fixing ac condenser fan?
here is what i have checked so far.
1. fuse is ok
2. relay is ok
3. water tem switch is ok
4. ground at condenser fan motor is ok
5. fan motor is workinf ok (direct 12 volt supplied)
6. found open wire from relay to fan motor connector.
7. found open wire from water temp switch to relay.
should i just connect fan motor direct to ac compressor clutch?
my z was getting hot one day with ac on (outside temp was 103).
if i turn the ac off then engine temp drop to normal.
i was thinking because of malfunction of ac condenser fan cause the over heating problem.
any body had this symptom to your turbo z (mine is 1986)
help need it here .
thanks for reading.
mike
1. fuse is ok
2. relay is ok
help need it here .
thanks for reading.
mike
TigroGT
10-20-2014 06:33 PM
Spurs212095
06-05-2012 10:02 AM
